Any electronics gurus around?, Need help identifying a diode. |
Aug 21, 2006 - 2:21 AM |
Enthusiast Joined Oct 16, '02 From Hohenwald, Tennessee Currently Offline Reputation: 1 (100%) |
I won't go into too much detail until I can find someone that knows what I'm talking about. I just need help identifying a diode based on the color strips that are on it.
Aug 21, 2006 - 7:26 PM |
Enthusiast Joined Jul 6, '06 From Columbia, MD Currently Offline Reputation: 0 (0%) |
Color codes are for resistors. Are you sure you're looking at a diode? The diode should just have a voltage listing and a stripe on one end to indicate which direction it goes.
Aug 21, 2006 - 7:56 PM |
Enthusiast Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
QUOTE(andrewb0x29a @ Aug 21, 2006 - 8:26 PM) [snapback]471387[/snapback] Color codes are for resistors. Are you sure you're looking at a diode? The diode should just have a voltage listing and a stripe on one end to indicate which direction it goes. x2 edit: if it ends up being a resistor, i have some books for colors..there from highschool, id have to find them This post has been edited by devilsden97: Aug 21, 2006 - 7:57 PM -------------------- Kawi Love |
Aug 22, 2006 - 9:06 AM |
Hm... I was just assuming it was a diode. The location on the PCB is labeled D1. There are others labeled R1, R2... (resistors), and others labeled C1, C2... (capacitors). I guess I should have stayed in electronics class.
It has one orange color stripe on it, but I didn't see any numbers. |
Lo-Fi Version | Time is now: November 25th, 2024 - 12:28 PM |
