Help 3s-gte/ge guys..., Where to connect my oilcooler. ?? |
Aug 21, 2006 - 7:41 AM |
Enthusiast Joined May 17, '06 From Sweden Currently Offline Reputation: 0 (0%) |
HI i have a smal problem.. im about to mount a oilcooler in the front and i am not sure where to connect the lines, so ive snapped a photo. Maybe you 3s-gte owners know where your turbo lines are connected?
(I Have a 175hp eurospec 3s-ge) are the plugged lines above the oilfilter theones to use?? wich one?? Thoughts and ideas are welcome My car thanx / Rikard -Sweden oops i forgot klick the ( My car ) link to see the photo |
Aug 22, 2006 - 4:40 PM |
Enthusiast Joined Jan 3, '06 From The Netherlands Currently Offline Reputation: 6 (100%) |
If you have a eurospec 3S-GE then your car is already equipped with an oilcooler
-------------------- JDM ST205
Aug 23, 2006 - 3:34 AM |
Well actually no.. the only cooling beside the engine radiator and AC is a coolingline for the powersteering.
at least what i can find. |
Aug 28, 2006 - 11:24 PM |
Enthusiast Joined Jan 9, '05 From Under the car Currently Offline Reputation: 0 (0%) |
The best thing to buy is an adaptor which fits behind the oil filter, but dont be tempted to buy too big an oil cooler, or your engine will never reach operating temp.
Sep 15, 2006 - 12:55 AM |
Enthusiast Joined Jan 23, '05 From Malta Currently Offline Reputation: 2 (100%) |
The Factory oil cooler is attaced to the cylinder block, next to the water pump, it is cooled by the coolant it is not air to air cooler like the raidiator. the oil cooler is behind the the exhaust manifold, probably not visable until at least the heat shild is removed, there are also 2 hoses connected to it
This post has been edited by Alan: Sep 15, 2006 - 12:57 AM -------------------- |
Sep 15, 2006 - 9:01 PM |
I thought the Oil cooler was tucked down next to the radiator.....just between the rad and the lights
Sep 16, 2006 - 3:29 AM |
Nope! thats the powersteering oil cooler did you find it yet?
This post has been edited by Alan: Sep 16, 2006 - 3:30 AM -------------------- |
Lo-Fi Version | Time is now: December 4th, 2024 - 3:38 PM |
