> Suspension kinda if'fy, what would i look for?
post Aug 21, 2006 - 3:53 PM
m0dd3d1
Joined Jan 30, '06
From Augusta, GA
If I wanted to just get under my car or get in the wheel well or w/e and check out my suspension b/c it's making some noises and is feeling not as good as it used to (only recently), what exactly would I look for, does anyone know? There's a littel rattling when I go over bumps/potholes. I recently took it to Toyota and they tightened the subframe & left front suspension b/c they said they found bolts loose, it doesn't rattle as much, but is still apparent. Thanks for you time guys/girls. Cheers.
-Triscuit
1998 Toyota Celica GT
2007 Subaru Impreza WRX STi
2007 Toyota Tacoma 4x4
1974 Datsun 260Z
1997 Subaru Legacy L Wagon
post Aug 21, 2006 - 3:56 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
too bad you live so far away from so cal, i would check it out for you...check the sway links, struts, control arms, sway bar, etc
post Aug 21, 2006 - 4:32 PM
Culpable04
Joined Apr 17, '06
From New Jersey
I had the same problem and I changed my links ( all 4 ) and bushings and now the problem is gone smile.gif
Lo-Fi Version Time is now: February 22nd, 2025 - 1:34 AM
