> Short Gearbox for 2.0 16v, For Rallying in Spain
post Aug 23, 2006 - 2:33 AM
otes3000
Joined Aug 22, '06
From Spain
Hello, I'm from Spain and I'm going to prepare my Celica 6gen GT 2.0 16v 175hp 3S-GE for rallys (sorry for my english, there is a lot of vocabulary that I don't control about cars)
I'm trying to find a short gearbox for my car but I can't. I've found for the GT4 version, but I supose that it can't fit on mine.
Let me explain to you. I'don't know exactly how to call this. What I'm looking for is not the complete gearbox, it's just the pieces inside of it for making the gears shorter (at this moment the second gear goes to 100km/h and I want it to go to 80km/h) Do you know what I mean?
Thanks a lot!
This post has been edited by otes3000: Aug 23, 2006 - 6:16 AM
Saab 9-5 Aero 250hp / Peugeot 206 coupé-cabrio / Celica GT 3SGE 175hp
post Aug 23, 2006 - 6:44 AM
Kadett
Joined Mar 17, '05
From The Netherlands
Even with the ST205 gearbox you will end up going about 95km/h in 2nd gear. Its 110km/h in 2nd gear BTW if you go up to 7200 RPM on the 3S-GE
The only thing you can do to go a bit shorter is getting a USA GT transmission. It has a shorter Final Drive , the gears itself are the same. It was also used on Toyota Camry's with the 2.2 Liter 5S-FE block.
Final Drive Ratio US GT: 4.176
Final Drive Ratio EU GT: 3.944
It should give about 5-7 procent difference in speed.
post Aug 23, 2006 - 8:29 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
what about using some of the gears from a 1.8 celica? I wouldn't expect it to be geared the same as the GT as its a smaller 8valve engine.
or maybe something from another toyota would have the correct gear ratios?
post Aug 23, 2006 - 10:15 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
QUOTE(vsideboy @ Aug 23, 2006 - 8:29 AM) [snapback]471930[/snapback]
the 7afe isnt 8 valve, its 16.
you may have to get custom gearing made
post Aug 23, 2006 - 3:23 PM
freakyre33c
Joined Jan 29, '06
Get an XTRAC gearbox they make them for all sorts of cars, the make them ecspeciall for rally. its a sequential gearbox too, bit pricey though, if you have a bottomless pit of money to spend get this. http://www.xtrac.com/mainindex.htm u can have one built for you they make a rally one already but i dk if it will fit your specification
post Aug 24, 2006 - 7:40 AM
otes3000
Joined Aug 22, '06
From Spain
QUOTE(freakyre33c @ Aug 23, 2006 - 3:23 PM) [snapback]472087[/snapback]
Ufff, that's too expensive for me.
That gearbox could cost more than the celica
post Aug 24, 2006 - 11:45 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
We have one guy wanting taller gearing... and now another wanting shorter... hahaha...
Umm... if it hasn't been mentioned already... a US version S54 will get you a higher final drive, which will shorten all of your gears... but it's not that big of a difference. Maybe if you ran smaller wheels?
post Aug 25, 2006 - 12:11 PM
otes3000
Joined Aug 22, '06
From Spain
QUOTE(Kwanza26 @ Aug 24, 2006 - 11:45 PM) [snapback]472635[/snapback]
I can't go with 15 inches because of the brakes. They are 13 inches big with 8 pistons. In the pictures you can see it with the fifteen's but I've bought 12 rims of 17 inches for racing.
post Aug 27, 2006 - 9:29 AM
freakyre33c
Joined Jan 29, '06
research on google. i've seen guys that build them just for that, i've seen the subaru ones and they made a gt4 one too, just look around http://www.quaife.co.uk/catalogue/page63.htm check this out.
This post has been edited by freakyre33c: Aug 27, 2006 - 9:32 AM
post Aug 28, 2006 - 7:53 AM
otes3000
Joined Aug 22, '06
From Spain
QUOTE(freakyre33c @ Aug 27, 2006 - 9:29 AM) [snapback]473359[/snapback]
Thanks, I've sent them an e-mail asking. I've seen close gearkits for GT4, but I don't know if they can fit on mine
Thanks
post Aug 29, 2006 - 1:57 AM
BLADDER_MASTER
Joined Dec 8, '04
If you're interested, get a tranny from a 92-93 Celica GT. They have the 4.1 final drive that we get over here.
post Aug 29, 2006 - 2:57 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
QUOTE(Bitter @ Aug 23, 2006 - 4:15 PM) [snapback]471964[/snapback]
ok, but the UK 1.8ST runs a toyota carina engine which is an 8 valve.
post Aug 29, 2006 - 4:56 AM
BLADDER_MASTER
Joined Dec 8, '04
QUOTE(vsideboy @ Aug 29, 2006 - 2:57 AM) [snapback]474017[/snapback]
I don't know, but this page tells me that a 1.8L Carina has 16 valves:
http://www.carfolio.com/specifications/mod...5965&Toyota
post Aug 29, 2006 - 4:58 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
QUOTE(BLADDER_MASTER @ Aug 29, 2006 - 10:56 AM) [snapback]474021[/snapback]
They will probably be 16V now, but back in 94 - 99 I think they were 8V. Could be wrong, I'm just going from what a mechanic told me.
post Aug 29, 2006 - 10:37 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(vsideboy @ Aug 29, 2006 - 9:58 AM) [snapback]474022[/snapback]
Toyota hasn't run an 8 valve motor in a small car since the 80's. The last one's were the 22R's in the trucks, which stopped in 1994.
Also... gear sets for the ST205 aren't gonna work. Different tranny.
This post has been edited by Kwanza26: Aug 29, 2006 - 10:38 AM
Lo-Fi Version Time is now: February 22nd, 2025 - 12:00 AM
