> Lip Kit Pics, What do you think? 56k warning
post Jun 22, 2003 - 11:41 AM
JStanger
From Ohio
I have a guy near me who said he will sell me this kit for $250.00. I haven't seen one of these kits off of the car other than this one but I think the side skirts look kinda weird. What do you think? Especially look at the last picture. The picture of the crack is on the very bottom of the front lip on the right side. How much would that cost to get fixed? Here is the LINK
This post has been edited by JStanger: Jun 22, 2003 - 11:42 AM
post Jun 22, 2003 - 2:05 PM
boosted_K2
Joined Aug 30, '02
From Michigan
if you can work with fiberglass buy it for sure, thats a pretty easy fix. just know thats probably not a VIS kit...
No but I don't buy it
Cause I'm...
post Jun 22, 2003 - 2:53 PM
Cragspider
Joined Aug 30, '02
From Franklin,Tn
yeah Tims right, its not the VIS kit. Its the 404. Look at my profile you will see the VIS sides. But fiberglass isn't hard to repair.
Bryan
post Jun 22, 2003 - 3:18 PM
JStanger
From Ohio
Do the side skirts look funny
post Jun 22, 2003 - 3:21 PM
Cragspider
Joined Aug 30, '02
From Franklin,Tn
They don't look funny, there just not the VIS sides, they look more like the stock sides, thats all.
Bryan
post Jun 22, 2003 - 6:04 PM
No0bOne
Joined Jan 5, '03
From Bay Area
Hey Jstanger, try to blurr your sigs bg leaving the car clear,...i think it'll create a drift-like effect if you know what i mean.
post Jun 22, 2003 - 6:34 PM
JStanger
From Ohio
I do not understand what you are saying here
post Jun 22, 2003 - 8:13 PM
ToYCeLi8
Joined Mar 6, '03
From South Central Los Angeles and Long Beach, CA
QUOTE (No0bOne @ Jun 22, 2003 - 3:18 PM)
You're right, that would look tight!!
post Jun 22, 2003 - 8:47 PM
JStanger
From Ohio
What in the hell are you guys talking about LOL
post Jun 22, 2003 - 8:53 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
if you... like blur the picture from the left of your car it will look like your car is sliding into the spot from the side.
post Jun 22, 2003 - 8:57 PM
JStanger
From Ohio
oh ok I see I see. Someone want to do it for me ?
post Jun 22, 2003 - 9:06 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
as far as the crack goes, you just need to thin the paint in the area around the crack, snad the edges smooth as you can around the crack, then go to autozone, buy for $11.99 a kit that comes with a fibreglass mat, resin, hardener and a spreader
go home, cut a sheet about 2" by 2", mix the hardener with the resin(read instructions for measuring amount) take a paint brush, and spread over the fiberglass sheet, soak it with the resin/hardener, slap the piece over the crack and use the spreader to flatten the fiberglass to lay flush with the rest of the lip.
let it dry a few hours, then take a power sander and sand down the patch, once its flat, use sandpaper to smooth the surface(go from 150 - prolly 1000 grit)
then take it somewhere to be painted
total extra cost of $11.99 + your time cause I'm guessing youll have to get the lip repainted regaurdless
goodluck
Lo-Fi Version Time is now: February 24th, 2025 - 1:28 AM
