4 Pages V  « < 2 3 4
> the 4th gen 3s....(aka st215), people dont seem to like it much?
post Sep 3, 2006 - 11:12 PM
very nice. i figured it was FAR from stock with 330hp at the wheels
post Sep 3, 2006 - 11:37 PM
Herbalife
Joined Sep 3, '06
From Jamaica
QUOTE(lagos @ Sep 3, 2006 - 11:12 PM) [snapback]475917[/snapback]
Oops...I forgot about the clutch kit....Exedy Twin-Plate Clutch..same unit as the one used in the SW20/ST185
post Sep 4, 2006 - 6:53 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
QUOTE(easternpiro1 @ Aug 30, 2006 - 12:11 AM) [snapback]474251[/snapback]
3sgte link
WELL WELL WELL...look what i found...its interesting....
thanks phattyduck i guess most of the things will fit hopefully, but still it is a big risk involved...the motor should be in soon what do u guys think about that link?
I think it's silly to make an issue about the ST215 3SGTE not being the 4th gen. I mean, the ST165 has the 1st gen, the ST185 has the 2nd gen, the ST205 has the 3rd gen, and the ST215 has the 4th gen. Each engine is by and large the same, but there are differences between each of them. The 4th gen has a LARGE air/air intercooler, coil on plug ignition, it's OBD2, side-feed intake manifold, one piece exhaust manifold/turbine housing, makes a different hp rating, etc. There are enough differences to classify it as a new generation, I don't see why it shouldn't be known as the 4th Gen.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Sep 5, 2006 - 10:31 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
wow ive been gone a while! dropped the car off on sat (some saw pics of themotor via message) i would like to see your car though herba...sounds good.
post Sep 7, 2006 - 2:33 AM
teamchancery
Joined Jun 25, '06
From miami
QUOTE(Herbalife @ Sep 3, 2006 - 11:01 PM) [snapback]475912[/snapback]
QUOTE(lagos @ Sep 3, 2006 - 10:10 PM) [snapback]475903[/snapback]
QUOTE(Herbalife @ Sep 3, 2006 - 11:03 PM) [snapback]475901[/snapback]
Hi all, Just joining up and following the threads....i have a 2000 Caldina GT-T equipped with the ST-215....most parts (except the obvious, like the coils) are common between the ST-205 and ST-215....belts, gaskets should work on both...
I'm currently doing a little upgrading here and there, but haven't really encountered any hiccups except for the exhaust manifold which is GOING TO LEAK AT SOME POINT IN TIME ( it comes with 7 holes for bolting it to the head....the head itself has provision for 8 studs, but comes with seven...go figure...the upper hole for cylinder #1 has no stud to go over.....its just...there..)
Aside from this, the engine/car performs flawlessly....Currently at 330whp / 310lb./ft.
any chance you can take some detailed pics of you motor and post them up in a new thread?
what mods do you have done to the motor? do you know what size injectors it comes with stock?
Pics to come later (as soon as i can find the digicam..lol)
Engine comes with 540cc injectors....i'm currently running :
880cc injectors
Clevespeed exhaust manifold w/ Garrett T3/T4BB turbo
Turbonetics 38mm Deltagate II
3" full custom downpipe/exhaust w/Apexi N1 canister
Evolution 8 front-mounted intercooler
CP 9:1 forged pistons
Crower Rods
ST-185 gearbox/transfer case/rear diff/front axles (my car came with a tiptronic tranny)
ARP head studs
Turbo XS RFL blow-off valve
Walbro fuel pump (to be installed)
GReddy E-Manage Ultimate (installed...not yet tuned)
GReddy Profec B boost controller
GReddy Turbo Timer
Catch can
Porterfield R4 Carbon Kevlar pads grabbing slotted stock-sized TRD rotors ( I have a full Brembo rotor/caliper
set from an Evo 8 to install )
WAYDO lowering springs ( sold through TRD Japan)
18" Privat wheels w/ 225/40zr18 Goodyear F1 GSD 3 tires
east good luck on the swap hope it goes well and from what ive heard about dr tweak you in the right hands.
Herbalife you deh pon tour man inna the other forums tho.Never knew so much things going on for your caldina.(jus a jamaican a hail you up i have asked you couple questions on wheels)
Anyway good luck with the swap ,i am interested to here how yours go as i have a swap with the same engine which is being finished up now its a
4th gen 3sgte in a ae110 1999 toyota levin
mods are light and like you i want to see what the 4th gen can do
using a celica alltrac 4wd gearbox converted to fwd
3 inch exhaust sysytem(no cat converter)
13 lb lightweight flywheel
stage 3 clutch kit
spearco fmic
turbo xs type hrfl
kyb agx 4 way adjustable shocks with celica front springs
walbro fuel pump
will be running a little extra boost over stock
i must say tho my mechanic has explained to me that this 3s runs very hot so temperature in engine bay will be an issue suffice to say i cant run my top mount IC even tho it looks so lovely with it.My mechanic has worked on 4th 2nd and 1st gen not sure bout 3 but i will ask him about parts for it and similaritites
This post has been edited by teamchancery: Sep 30, 2006 - 6:51 PM
post Sep 7, 2006 - 1:22 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
thanks man for the support! if he's worked on those he should be fine! at least i know i wont have to go too far for aftermarket support! smile.gif biggrin.gif
4 Pages V  « < 2 3 4
24 User(s) are reading this topic (24 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 24th, 2025 - 9:09 AM
