> Drivers Side Window, Wont go down, but seems like it will go up...
post Aug 26, 2006 - 12:05 PM
Dm_Vinny
Joined Apr 4, '05
Ok I don't really know for sure if my motor's shot because it clicks and pushes the window up, but going down it does nothing... Could my motor be shot one way?
post Aug 26, 2006 - 6:24 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
You might have broken the plastic round wheel. My car did the exact thing. its a pain in the butt to change!
post Aug 26, 2006 - 9:03 PM
Stu37363
Joined Jun 30, '05
From Chattanooga, TN
the window is cable driven, and if that wire frays is may cause a similar reaction.
as far as i know toyota only sells that system in two parts... motor and window regulator, possibly the casing the motor bolts into is a seperate part.
here is a walkthrough for changing the regulator if that will help you any Link
This post has been edited by Stu37363: Aug 26, 2006 - 9:07 PM
post Sep 6, 2006 - 4:30 PM
DmVinny
Joined Feb 23, '03
From Florida
Well the problem is u know when u roll up and down ur window the lights dim usually...
Well the lights dim when i try and roll it up, and i hear the clicking of the motor, but when
i roll it up i hear nothing and no lights dim...
think it might be the switch?
post Sep 6, 2006 - 4:47 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
maybe the switch... when mine went bad it was a frayed cable. I got the whole assembly from a junk yard, I can't imagine it being seperate. If you feel comfortable pull your door panel and wtach what it does, that should answer your question right away.
post Sep 6, 2006 - 4:49 PM
DmVinny
Joined Feb 23, '03
From Florida
Ya I pulled out my door panel nothing happens except when i try to roll it up it clicks the motor but of course the window's up so nothing has to happen...
post Sep 6, 2006 - 4:55 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
so you didn't see any damage to the cable? Is it like a binding click or more the like the sound of a bad starter?
post Sep 8, 2006 - 6:21 PM
mike96ST
Joined Mar 17, '04
From Lansing, MI
pull apart the actual switch....I had it happen to me a few months ago where my pass. side window would roll down but was off/on for rolling up, sometimes not at all! turns out i looked in the pass. side window switch and the contact was competely fried. I had to get a replacement from the dealer --- $75 for just the pass. side switch. Better hope its not the driver side, I think that one went for at least $150.......
Lo-Fi Version Time is now: November 29th, 2024 - 10:01 PM
