Lost Wheel Lock Key..., What should I do now? |
Aug 26, 2006 - 9:50 PM |
Enthusiast Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
I took my car to a shop to get a new axle put in, to find out I have officialy lost my wheel lock key. I swear it was in the car somewhere... either I hid it so well that even I can't find it, or I forgot to put it back in after my previous wheel rotation.
So, what should I do now? -------------------- |
Aug 26, 2006 - 10:00 PM |
Enthusiast Joined May 20, '05 From sacramento, ca Currently Offline Reputation: 1 (100%) |
QUOTE(tomazws @ Aug 26, 2006 - 7:50 PM) [snapback]473239[/snapback] I took my car to a shop to get a new axle put in, to find out I have officialy lost my wheel lock key. I swear it was in the car somewhere... either I hid it so well that even I can't find it, or I forgot to put it back in after my previous wheel rotation. So, what should I do now? what type of lock is it? i believe you can use a socket and hammer it onto the lock and presto....i took off a set of 94-96 gsr rims at the junk yard like that before using a size 19mm(i think, i'm not sure what size it's been too long)... This post has been edited by kenjamatic: Aug 28, 2006 - 12:12 PM |
Aug 26, 2006 - 10:30 PM |
Enthusiast Joined Aug 22, '06 From jax,fl Currently Offline Reputation: 0 (0%) |
I work for pepboys and we have a specail socket for lugs that are rounded. I used it to take off lug locks before. Go there they shouldn't charge you unless there dicks. We don't because it so easy.
Aug 28, 2006 - 11:50 AM |
QUOTE(vg30dett93 @ Aug 26, 2006 - 8:30 PM) [snapback]473251[/snapback] I work for pepboys and we have a specail socket for lugs that are rounded. I used it to take off lug locks before. Go there they shouldn't charge you unless there dicks. We don't because it so easy. I went and they told me to go to a tire shop instead.. hmm.. -------------------- |
Aug 28, 2006 - 11:54 AM |
Enthusiast Joined Jan 26, '05 From Ashville, Ohio Currently Offline Reputation: 2 (100%) |
try discount tire i used to work for them and we had all kinds of keys
Aug 28, 2006 - 12:06 PM |
Enthusiast Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
dealership will have it......
-------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Aug 28, 2006 - 12:19 PM |
if you kept the little label that came with the lugnuts when you bought them you can order another key. the label has the factory brand name, model and a key code. along with the address and phone number of where to order a new key.
Aug 28, 2006 - 5:31 PM |
Enthusiast Joined Jul 28, '06 From Delaware Currently Offline Reputation: 0 (0%) |
weld on an old socket and wrench it off...if you have the means to do it.
Sep 3, 2006 - 4:59 AM |
It's an aftermarket lock, got it from America's Tire... they are Gorilla Locks, though... they don't have the serial number of my lock in the computer, so I can't take it to Gorilla and order an new key... brought to tire shops... all 3 of them said they'll need to break them, and might damage my rims... Contacted Gorilla again, and they told me they actually have something to take it out... so... let's see on that when they open again after labor day...
Sep 3, 2006 - 5:05 AM |
Enthusiast Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
well goodluck and keep us updated on what happens
Sep 8, 2006 - 11:31 PM |
Enthusiast Joined Jun 25, '06 From Bremerton, Washington Currently Offline Reputation: 1 (100%) |
les shuawb
Sep 9, 2006 - 4:57 PM |
Turned out that America Tire Co. DOES have my key... so I got the key yesterday, quickly, but slowly drove my car to this shop to get my driver side axle swapped, but discovered the right front boot was cracked too. So ended up replacing the right front boot too..
Now... my car has really bad alignment. **** never stop coming at me... -------------------- |
Sep 11, 2006 - 2:14 PM |
discount tire and pepboys i beleive both carry the gorilla keys, all you need to know is the key number.
Lo-Fi Version | Time is now: November 26th, 2024 - 5:49 AM |
