Enthusiast ![]() ![]() Joined Dec 21, '05 From Ontario Currently Offline Reputation: 1 (100%) ![]() |
I tried to do quick search beause I'm in a rush but no luck. Could someone tell me how to remove the license plate holder plastic piece that is between both tail lights. I need to get to the frame so I can put some dynomat cuz my plate keeps rattling bad.
You can use this pic (thanks to batman) to help descibe it to me .. I already took off the interior plastic so i can go from there I think I jsut need to know wut bolt (and how many) need to come off ![]() |
first, remove the tails. There is a bolt on either side of the plate holder behind the tails. The holder is held in by plastic "pegs", just pull on the holder and it will come strait out.
here is a pic, not the best but all I have right now (you can see 3 of the white pegs in the pic) ![]() -------------------- |
just pull on the pegs with plyers and itll come out? I was gonna do that but i didnt wanna break em.
(btw thanks for the explanation) |
![]() Enthusiast ![]() ![]() ![]() Joined Jul 9, '04 From Las Vegas USA Currently Offline Reputation: 14 (100%) ![]() |
Or you can do like I did... put the dynomat under the plate itself. Works great, no hassle, looks stock.
QUOTE(coldbluesteel @ Aug 28, 2006 - 7:05 PM) [snapback]473870[/snapback] Or you can do like I did... put the dynomat under the plate itself. Works great, no hassle, looks stock. Yea i tried it but there was still rattling. I found out its from the light that shines on the plate. Somethings loose in there |
QUOTE(kash1355 @ Aug 29, 2006 - 12:22 AM) [snapback]473893[/snapback] QUOTE(coldbluesteel @ Aug 28, 2006 - 7:05 PM) [snapback]473870[/snapback] Or you can do like I did... put the dynomat under the plate itself. Works great, no hassle, looks stock. Yea i tried it but there was still rattling. I found out its from the light that shines on the plate. Somethings loose in there you should be able to pull those and see whats loose. -------------------- ![]() |
Enthusiast ![]() Joined Jun 28, '07 Currently Offline Reputation: 0 (0%) ![]() |
first, remove the tails. There is a bolt on either side of the plate holder behind the tails. The holder is held in by plastic "pegs", just pull on the holder and it will come strait out. here is a pic, not the best but all I have right now (you can see 3 of the white pegs in the pic) ![]() I am trying to remove the bumper cover so I can see if there is any hidden damage from a rear-ending. I am stuck on the plate holder/panel. I have all the pegs out, but the panel is still being held near the top center. Something to do with the license plate lights? |
Lo-Fi Version | Time is now: February 19th, 2025 - 5:33 PM |
