> 6 quarts of oil since Friday? whats going on
post Aug 30, 2006 - 6:05 PM
BlackCelicaGT94
Joined Mar 4, '03
From Kirkland, Washington
So im assuming i have a leak. Ive always had a small leak but 6 quarts since Friday is rediculous.
Any other possibilities if its not a hole or something?
I need a new 5sfe within the next few months :-( blah!
post Aug 31, 2006 - 2:38 PM
well can you see visual puddle/drops under your car?
post Aug 31, 2006 - 2:46 PM
creis
Joined Jan 10, '04
From Shoreline, WA
someone is syfoning your oil!!!
how many miles? check your coolant and make sure is clean (not getting oil in it.) and keep a close eye under the car when your parked. could be a number of things though.
? I can think of a diff motor that would be a better choice and get you closer to that gt-4 clone status smile.gif
post Aug 31, 2006 - 3:13 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
to loose that much there must be a leak, tricky thing is that the leak may only be loosing oil when the oil pressure is at a certain level.
post Aug 31, 2006 - 3:32 PM
hitcachi
Joined Jun 19, '05
From Nebraska
let the motor warm up to normal op temp and then take a trouble light and check for leaks in the obvious places first. Around gaskets and seals, oil filter, bolt, pan.
post Aug 31, 2006 - 4:16 PM
urbandork
Joined Jul 16, '04
From Los Angeles
omg lol i have a noticable leak from the pan and my #1 cylinder is burning oil and i only use about a quart in a week/200 miles or so .
its odd u dont notice 6 quarts going some where. smoke from the tail pipe, smoke from the engine bay, and a puddle of oil on the ground should be noticable.
good luck with the search
post Sep 1, 2006 - 12:12 AM
rayneezy23
Joined Jun 25, '06
From Bremerton, Washington
what if you have oil in yor coolant?
post Sep 1, 2006 - 12:28 AM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
oil pump could have a leak in it
post Sep 1, 2006 - 1:00 AM
rayneezy23
Joined Jun 25, '06
so im assuming thats really bad
post Sep 1, 2006 - 9:43 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
Either you have a huge oil leak...or your piston rings are shot
post Sep 1, 2006 - 11:15 AM
bindertch
Joined Aug 18, '04
From Silverdale, WA
QUOTE(rayneezy23 @ Aug 31, 2006 - 11:00 PM) [snapback]475087[/snapback]
Yes oil in the coolant is bad. that means you have a head gasket leak.
I thought a quart about every 3000 miles was bad. You need to check everything. Mostly like Bitter said. I would make this a priority before you do any day to day driving. Wouldn't want it to run dry.
post Sep 1, 2006 - 11:35 AM
Steevo
Joined Jul 19, '06
From Colorado
QUOTE(Daftboy @ Sep 1, 2006 - 12:28 AM) [snapback]475078[/snapback]
If the oil pump was leaking it would have low oil pressure. The oil pump is in the crankcase.
post Sep 3, 2006 - 1:17 PM
alltracman78
Joined Aug 9, '06
From Ma
Any updates on it?
Unlikely you are burning even CLOSE to that much oil.
Unless you have HUGE clouds of blue smoke and a loss in power.
rings don't go that fast, unless you suddenly blew something.
And you should hear a noise at the very least.
If it's a leak, same thing.
You will have a pretty good sized puddle....
And they normally don't just happen that large either.
Unless something popped off....
Do you have any more info?
post Sep 3, 2006 - 4:51 PM
spunky393
Joined Apr 22, '04
From illinois
The rings are not bad, she has probably BROKEN a ring. Hell, it probably looks like a dang mosquito fogger running down the street. Good luck.
post Sep 3, 2006 - 5:09 PM
twolownissan2002
Joined Mar 22, '06
From Wesley chapel, Florida
do these car have oil cooler built in to the rad. if so your rad. might be bad ahd a friend with that problem
post Sep 4, 2006 - 1:35 PM
alltracman78
Joined Aug 9, '06
From Ma
I believe it's just a cooler on the block under the filter.
Coolant flows around the oil.
VERY unlikely it is leaking there, at least not into the coolant.
Lo-Fi Version Time is now: February 19th, 2025 - 7:55 PM
