Enthusiast ![]() ![]() ![]() ![]() Joined Apr 22, '04 From illinois Currently Offline Reputation: 0 (0%) ![]() |
Ok, here it is. Psalms 27:1 in a cross form.
I want the Psalms to be the long part of the cross. I want the 27:1 to be the short part of the cross. Then outlining the Psalms 27:1 shaped in the form of a cross, I want it to be kind of a tribal/thorn outline. I very much appreciate it. Ask question if you need to, and thanks for the consideration of helping -------------------- ![]() The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
none?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) ![]() |
I could help you but I can't see your pic. try to send it to my email ! because my PC at home is.. well is not. and at work there is such a high security that I barely can see the posts.
send the pic and the description of what you want and I'll do it over the weekend. -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Jul 31, '05 From Southern California Currently Offline Reputation: 7 (100%) ![]() |
if you are serious about getting it tattooed then at a tattoo shop they will draw up a stencil for it anyways and more than likely they might have some ideas that you might have not thought about for it.... and then the artist who had drawn it up for you would also be the one PERMANENTLY drawing on your skin... shouldn't cost extra either... sounds pretty good as far as design
Lo-Fi Version | Time is now: February 22nd, 2025 - 11:02 PM |
