> oil psi gauge
post Aug 30, 2006 - 10:27 PM
spke719
Joined Dec 31, '04
From white hall, Maryland
ok i hook it all up, put the sensor in the head where it goes, and i touch the sending wire to the sending unit and the gauge jumps all the way up to 100 y is that. ????? i rewired and it still does the same thing, new sending unit...does the same thing. what could possibly be wrong???? HELP!!!!! (spke719)
[font=Comic Sans Ms][size=3]
SI VIS PACEM PARA BELLUM (if you wish for peace, prepare for war!)
post Aug 31, 2006 - 2:04 AM
hitcachi
Joined Jun 19, '05
From Nebraska
what you should get is a mechanical oil pressure gauge. Not an electrical one.
post Aug 31, 2006 - 2:14 AM
QUOTE(spke719 @ Aug 30, 2006 - 11:27 PM) [snapback]474705[/snapback]
your grounding out your singal wire on the body of the sender. the signal wire should only touch the threaded part that it gets hooked up to. there should be some type of a gasket around the bolt that sticks out of the sender, to prevent it from grounding out on the body of the sender.
This post has been edited by lagos: Aug 31, 2006 - 2:20 AM
post Aug 31, 2006 - 5:16 PM
spke719
Joined Dec 31, '04
QUOTE(lagos @ Aug 31, 2006 - 2:14 AM) [snapback]474747[/snapback]
im only touching it to the threads and it grounds out.
Lo-Fi Version Time is now: January 11th, 2025 - 7:39 PM
