> Altezza (Black Top) BEAMS, In a 6gc
post Sep 1, 2006 - 8:44 AM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
So today on the way to school I was thinking about this thread:
http://www.6gc.net/forums/index.php?showtopic=40694
I thought the Altezza's BEAMS motor, was a v6. Then when I made it to class, I was thinking about it again, then I thought it was an Inline 6. Then after searching here, I found this thread:
http://www.6gc.net/forums/index.php?showto...lack+Top)+Beams
If you look at the exaust manifold in one of the pictures (it shows a side view of the motor, manifold side) it leads me to believe that it is an Inline 4. So this brings up 2 questions.
What is the Altezza (black top) BEAMS motor? (Inline6 or Inline4)
[if the answer is Inline6, then ignore the next question, I know an Inline6 won't fit because it has to be mounted Longitudanaly, in the engine bay, and won't fit between the strut towers.]
IF it is an Inline4, it should fit in the celica right? (with the 3s-ge transmission)
I know the common idea is, "there is no way u can get it in." so Im really wondering, What exactly makes it not fit? (from the pictures it seems the Intake manifold, and the Exaust manifold are pretty large, and might cause problems, but as i keep looking at it, it doesn't seem impossible.
(I used the search function, and Searched "Altezza (black top) BEAMS")
This post has been edited by devilsden97: Sep 1, 2006 - 8:46 AM
Kawi Love
post Sep 1, 2006 - 9:06 AM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
i think its just a matter of finding the right tranny and getting it all mounted in the car
-Brian
post Sep 1, 2006 - 9:58 AM
noobsauce its an Inline 4....its just a 3sge..
and the only reason it wouldn't fit is the transmission would more then likely hit the firewall....but thats easily fixable with some cutting and welding smile.gif
post Sep 1, 2006 - 3:55 PM
devilsden97
Joined Jun 13, '05
well that sounds like a weak excuse.
Kawi Love
post Sep 2, 2006 - 1:29 AM
then do it
post Sep 2, 2006 - 4:42 AM
bindertch
Joined Aug 18, '04
From Silverdale, WA
The engine from that auction wouldn't mount up that easy. If like devilsden said you use the regular 3SGE transmission and a different header it might fit. It also might be too tall due to that it sits vertical and not on an angle like the 3SGTE or the 5SFE. You might be able to adapt an oiling system from one of those engines but it might not work 100% because of the different angles.
This post has been edited by bindertch: Sep 2, 2006 - 4:42 AM
post Sep 2, 2006 - 8:49 AM
devilsden97
Joined Jun 13, '05
QUOTE(playr158 @ Sep 2, 2006 - 2:29 AM) [snapback]475368[/snapback]
then do it
i cant, just your reasoning sounds like a very weak excuse.
QUOTE(bindertch @ Sep 2, 2006 - 5:42 AM) [snapback]475394[/snapback]
While this sounds more logical
Kawi Love
post Sep 2, 2006 - 11:26 AM
weak excuse for wat?
with 5sfe engine mounts and a GT transmission it would bolt right in noproblem as a FWD platform..wiring would be your issue...it would swap nearly identical to any 3sge/3sgte motor (although the holes for the motor mounts MIGHT not be there, that would then take some creativy mounting them)
now if your creative such as i was thinking you'd need to make custom engine brackets and mount it the otherway and run the stock transmission as pictured with a modified trans tunnel and a GT4 custom rear end wink.gif god think outside the box
This post has been edited by playr158: Sep 2, 2006 - 11:29 AM
post Sep 2, 2006 - 12:27 PM
Kadett
Joined Mar 17, '05
From The Netherlands
Even if you sort out if the GT tranny and mounts are a direct fit (which the probably do) you still need to sort out how you want to route the air intake since its on the wrong (no space) side of the car.
post Sep 2, 2006 - 12:53 PM
sugarfree
Joined Dec 21, '05
From dallas
Use the redtops intake manifold.
post Sep 2, 2006 - 2:03 PM
Kadett
Joined Mar 17, '05
QUOTE(sugarfree @ Sep 2, 2006 - 7:53 PM) [snapback]475467[/snapback]
So then whats the whole point of getting the Blacktops then laugh.gif laugh.gif
post Sep 2, 2006 - 6:27 PM
BLADDER_MASTER
Joined Dec 8, '04
Get a redtop. Blacktop ain't worth it.
post Sep 2, 2006 - 6:41 PM
devilsden97
Joined Jun 13, '05
QUOTE(BLADDER_MASTER @ Sep 2, 2006 - 7:27 PM) [snapback]475578[/snapback]
not debating worthyness (if thats a word) debating ideas on how to do it. or if its possible.
Kawi Love
post Sep 2, 2006 - 7:18 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
well yes it possible if you REALLY want the dual VVT-i that the black top has to offer and if you had the money and/or fabrication skills. Like mentioned here, a fwd transmission would need to be used to replace the rwd transmission included with that engine. Also mentioned was the intake manifold. yes it would need to be exchanged with another intake manifold with the air entry on the other side. Wiring is always an issue with any swap, so that is just exspected with this swap. A new exhuast manifold would also need to be fabricated to complete the swap. Ofcourse there is much more involved in this swap, but in terms of cost and effectiveness, this swap is not feasable, however it IS possible which is what you were asking. smile.gif
This post has been edited by MaskedMan: Sep 2, 2006 - 7:18 PM
post Sep 2, 2006 - 10:48 PM
QUOTE(Kadett @ Sep 2, 2006 - 1:27 PM) [snapback]475457[/snapback]
honestly if your going through the effort you think having to make a custom intake tube is a deturant...if your worried about making an intake tube..then you shouldn't even think of this to start...
post Sep 12, 2006 - 1:46 AM
ExSane
Joined Apr 17, '06
From under your bed.
QUOTE(playr158 @ Sep 2, 2006 - 10:48 PM) [snapback]475621[/snapback]
Just short ram the bish! And when you finally got the money, turbo it and you won't have to worry about the intake. And yeah, I say GO FOR IT! Anything is possible with money.
This post has been edited by ExSane: Sep 12, 2006 - 1:46 AM
post Sep 12, 2006 - 2:16 AM
burneeed
Joined Dec 18, '05
From BANNED
QUOTE(ExSane @ Sep 12, 2006 - 1:46 AM) [snapback]478857[/snapback]
Its not worth it its a na swap thats going to cost alot when you can get a 3sgte for around the same price range.
This post has been edited by burneeed: Sep 12, 2006 - 2:16 AM
BANNED!
post Sep 12, 2006 - 2:40 AM
ExSane
Joined Apr 17, '06
Wait... is it possible you can bolt on the red top intake manifold to make the intake throttle to the right instead? But paint it black before you put it on. Could it be possible... I wonder...
This post has been edited by ExSane: Sep 12, 2006 - 2:45 AM
post Sep 12, 2006 - 3:12 AM
burneeed
Joined Dec 18, '05
From BANNED
QUOTE(ExSane @ Sep 12, 2006 - 2:40 AM) [snapback]478868[/snapback]
BANNED!
post Sep 12, 2006 - 10:31 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
This topic is lame...
Blacktop BEAMS = 3SGE = direct bolt in
You're gonna need a header and FWD intake manifold (redtop *might* fit)... Also... the engine costs more than most 6th gens... so yeah... do it or don't.
Lo-Fi Version Time is now: November 28th, 2024 - 6:58 PM
