finished gt4 conversion, azian_advanced |
Sep 4, 2006 - 6:40 AM |
Part A - A How-To I've finally finished my gt-four front conversion.. to be honest, seeing it in person is a lot more surprising than in the pictures.. this is probably my best mod so far and was far beyond my first expectations.. perhaps i'm overexaggerating a bit but in short, this is definitely hotter than what i had in mind . it was not an easy task for me since my car was previously in an accident and the fenders, hood, and gt-four bumper didn't line up like it should. so washers were added onto bolts to fill gaps to align the fenders properly. but otherwise, you shouldn't have a problem since everything attaches the same way. i first thought that this was simply ALL BOLT ON but really wasn't. i mean, it was but it wouldn't fit and line up correctly... so a couple of things (for you future gt-four convertors) that needed modifications were: 1. cutting the st205 reinforcement bumper 2. the gap to fill between the bumper and hood the reinforcement bumper was not a direct bolt-on job... the front frame rails where the re-bar bolts on to is different on the gt4's. this is how it appears when you have it against the frame rails... as you can see, the bottom is far too forward for the upper threading to fit through... this is how it looks after being cut (using an impact metal sheet cutter): and here it is when bolted on another thing which i totally missed is when you have the bumper installed, the bar sits slightly higher than it should be. right now, it doesn't fit in the groove on the bumper absorber. that may be because my car was in a previous front end accident and things aren't lining up 100% perfect. to fill the gap between the bumper and hood, i used about 2.25" screws with a nut. the head of the screw and the nut clamps the bumper seal to the bumper plastic, and the bottom tip of the screw screws into the threading on the metal retainer. thank god i have tons of all sorts of screws in my garage. finding the right screw is gonna be hard. i've heard other members use the same thing but instead used washers to lift the bumper up high. either way is fine i guess, but i like my idea better. this is how mine looks like btw... some custom 4" lamps were put in. i bought them from a local hardware store for $8 each (which beats the ~$250 that they normally cost). though they don't mount onto the rebar but are just the lamps themselves.. i've read that another member used Mercury Topaz (or something) 4" fogs instead but i couldn't find those anywhere. besides, i like the crystaly (not sure if that's even a word ) look better. they're basically glued to the fog light housings though i'm not sure if the glue will hold because these lamps tend to get pretty hot when on. i don't think i'll be wiring them up anyway... that's all there is to know for the conversion.. it's relatively simple just takes some time. in my case, i also had the fenders that came off the clip where my bumper and hood came off of. so i ordered some jdm sidemarkers and wired them up to the turn signals.. this is also an easy mod and very appealing at night. --------------------------------------------- Part B - Becoming --------------------------------------------- Part C - Completetion [size=1] is this too many pics for one post? -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Sep 4, 2006 - 6:45 AM |
Enthusiast Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) |
This pictures are what I waited for... amazing work!
-------------------- No more replicas... This is evolution... This is SS-four :)
________[Featured Celica of 6gc.net @ 2010]_________ |
Sep 4, 2006 - 6:47 AM |
Enthusiast Joined Jan 9, '05 From Under the car Currently Offline Reputation: 0 (0%) |
Nice job.
Sep 4, 2006 - 7:23 AM |
QUOTE(azian_advanced @ Sep 4, 2006 - 6:40 AM) [snapback]475993[/snapback] the reinforcement bumper was not a direct bolt-on job... the front frame rails where the re-bar bolts on to is different on the gt4's. another thing which i totally missed is when you have the bumper installed, the bar sits slightly higher than it should be. right now, it doesn't fit in the groove on the bumper absorber. that may be because my car was in a previous front end accident and things aren't lining up 100% perfect. The rails aren't different and you shouldn't have to cut anything. You just need the right brackets: Frame Bracket RH 57201-20060 Frame Bracket LH 57202-20070 Also, judging by this picture: I'd say you need these parts as well: Seal, hood to front end panel 53395-20020 $19.92 This is the rubber seal where the hood and bumper meet Retainer, front bumper upper center 52521-20200 $25.44 this is the metal thing that holds the rubber in place Otherwise I think it looks pretty good. -------------------- Project ST204.5 99.88946% complete... |
Sep 4, 2006 - 7:51 AM |
QUOTE(WannabeGT4 @ Sep 4, 2006 - 8:23 AM) [snapback]476001[/snapback] QUOTE(azian_advanced @ Sep 4, 2006 - 6:40 AM) [snapback]475993[/snapback] the reinforcement bumper was not a direct bolt-on job... the front frame rails where the re-bar bolts on to is different on the gt4's. another thing which i totally missed is when you have the bumper installed, the bar sits slightly higher than it should be. right now, it doesn't fit in the groove on the bumper absorber. that may be because my car was in a previous front end accident and things aren't lining up 100% perfect. The rails aren't different and you shouldn't have to cut anything. You just need the right brackets: Frame Bracket RH 57201-20060 Frame Bracket LH 57202-20070 Also, judging by this picture: I'd say you need these parts as well: Seal, hood to front end panel 53395-20020 $19.92 This is the rubber seal where the hood and bumper meet Retainer, front bumper upper center 52521-20200 $25.44 this is the metal thing that holds the rubber in place Otherwise I think it looks pretty good. x2 on the frame brackets..props for creative thinking getting it to work tho, once you get the hood seal and retainer in, it'll look super! also..anything that says "gt-four" on a car thats not is kinda a pet peeve of mine..but again creative thinking.. nice work. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Sep 4, 2006 - 8:34 AM |
Enthusiast Joined Mar 16, '05 From Netherlands Currently Offline Reputation: 4 (100%) |
damm that is a mean looking car
Sep 4, 2006 - 8:44 AM |
Enthusiast Joined May 19, '06 From North NJ Currently Offline Reputation: 16 (100%) |
nice job man. the before and after pics are awesome. again, great job. wish i had the money and time to do this myself.
Sep 4, 2006 - 8:47 AM |
QUOTE(presure2 @ Sep 4, 2006 - 2:51 PM) [snapback]476005[/snapback] ... also..anything that says "gt-four" on a car thats not is kinda a pet peeve of mine..but again creative thinking.. nice work. IMHO... I have also SS-III sticker on my car and it's not SS-III at all (or Beams, TRD, superstrut suspension, etc.) . Professional will recognise that and amateur don't even care (if it's or it's not GT-four/SS-III)... but everyone see damn good looking car! That's my opinion about this... -------------------- No more replicas... This is evolution... This is SS-four :)
Sep 4, 2006 - 8:50 AM |
Enthusiast Joined Sep 13, '04 From Sydney/Australia Currently Offline Reputation: 2 (100%) |
holy smokes! that is hot!!!!
-------------------- ROM-23L 67 + 76 = 143
"I wasn't pursuing Sephiroth, I was being summoned by him." - Cloud Strife |
Sep 4, 2006 - 9:23 AM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
awesome! pics are great!! makes me want to switch and do a GT4 conversion
Sep 4, 2006 - 11:10 AM |
Enthusiast Joined Jul 4, '06 From winnipeg Currently Offline Reputation: 2 (100%) |
looks good...i saw it yesterday when you were leaving your work!!!
i was in the green celica...i actually just bought raiser blocks of babycakes on heights! anyway looks badass |
Sep 4, 2006 - 12:05 PM |
QUOTE(presure2 @ Sep 4, 2006 - 7:51 AM) [snapback]476005[/snapback] QUOTE(WannabeGT4 @ Sep 4, 2006 - 8:23 AM) [snapback]476001[/snapback] QUOTE(azian_advanced @ Sep 4, 2006 - 6:40 AM) [snapback]475993[/snapback] the reinforcement bumper was not a direct bolt-on job... the front frame rails where the re-bar bolts on to is different on the gt4's. another thing which i totally missed is when you have the bumper installed, the bar sits slightly higher than it should be. right now, it doesn't fit in the groove on the bumper absorber. that may be because my car was in a previous front end accident and things aren't lining up 100% perfect. The rails aren't different and you shouldn't have to cut anything. You just need the right brackets: Frame Bracket RH 57201-20060 Frame Bracket LH 57202-20070 Also, judging by this picture: I'd say you need these parts as well: Seal, hood to front end panel 53395-20020 $19.92 This is the rubber seal where the hood and bumper meet Retainer, front bumper upper center 52521-20200 $25.44 this is the metal thing that holds the rubber in place Otherwise I think it looks pretty good. x2 on the frame brackets..props for creative thinking getting it to work tho, once you get the hood seal and retainer in, it'll look super! also..anything that says "gt-four" on a car thats not is kinda a pet peeve of mine..but again creative thinking.. nice work. wow.. i didn't even know you can get those frame brackets... always thought they were fixed on the car. and about the seal and retainer, i just took the one off the old bumper and bent it to fit the new bumper so i can start using it asap.... it's almost a direct swap with different angle bends. but i think i'll buy the gt4 one anyway -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Sep 4, 2006 - 12:26 PM |
Enthusiast Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
QUOTE(malpaso @ Sep 4, 2006 - 8:47 AM) [snapback]476012[/snapback] QUOTE(presure2 @ Sep 4, 2006 - 2:51 PM) [snapback]476005[/snapback] ... also..anything that says "gt-four" on a car thats not is kinda a pet peeve of mine..but again creative thinking.. nice work. IMHO... I have also SS-III sticker on my car and it's not SS-III at all (or Beams, TRD, superstrut suspension, etc.) . Professional will recognise that and amateur don't even care (if it's or it's not GT-four/SS-III)... but everyone see damn good looking car! That's my opinion about this... most dont care because 90% of the american population doesnt even know what a gt-4 or SS-III celica is. Looks awesome. -------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Sep 4, 2006 - 12:42 PM |
Enthusiast Joined Feb 22, '03 Currently Offline Reputation: 0 (0%) |
Im just curious...Whats the difference between a base model Civic or Integra putting on a Type R sticker or somethin along that line and a Celica with a GT-4 / SSIII badge on it? Yet the Civic and Integra owners are called ricers but the badging on Celicas, they're considered cool. Everytime i come on this site, i hear stories about a riced out Civic but when the Celica has the same modifications, its considered cool. Im just confused by this. Im NOT ragging on ur car cuz i think it looks nice, but i dont get some of ur peoples train of thought. Wouldnt that be considered hypocricy?
-------------------- Note to new members. Discussions such as the ones below are forbidden.
http://www.6gc.net/forums/index.php?showtopic=26310&hl= |
Sep 4, 2006 - 2:01 PM |
Enthusiast Joined Dec 8, '05 From torrance/carson, ca Currently Offline Reputation: 11 (100%) |
looks sweet. plus another great how-to article. good job. nice pics.
-------------------- ss-iii splitters and 404 skirts are on. which means i need to update my sig. |
Sep 4, 2006 - 2:58 PM |
Enthusiast Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) |
looks great. its something id love to do..but I dont have that kinda money to be tossing around. I'd even finish it with real 3 spokers.
Sep 4, 2006 - 3:29 PM |
QUOTE(Sh0gunkid8721 @ Sep 4, 2006 - 12:42 PM) [snapback]476054[/snapback] Im just curious...Whats the difference between a base model Civic or Integra putting on a Type R sticker or somethin along that line and a Celica with a GT-4 / SSIII badge on it? Yet the Civic and Integra owners are called ricers but the badging on Celicas, they're considered cool. Everytime i come on this site, i hear stories about a riced out Civic but when the Celica has the same modifications, its considered cool. Im just confused by this. Im NOT ragging on ur car cuz i think it looks nice, but i dont get some of ur peoples train of thought. Wouldnt that be considered hypocricy? Sh0gunkid8721, ....... eat your heart out. -------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Sep 4, 2006 - 4:01 PM |
hahah.. nice..
anyway, i've been toying out about putting that gt-four emblem on the upper grill there. i knew i'd get some feedback regarding that. imo, i really like the way it looks with the emblem on, but i also dislike the fact that my car just isn't a gt4. so far, the locals here have only given compliments and most of them don't even know what the heck i'm driving and give me pointed fingers and confused looks. heck, i get a good laugh everytime it happens. but exactly what malpaso said, most people won't recognize it since all they'll be looking at is a rare nice looking car (not to be bragging but just to get the point out). only the real enthusiasts (mainly on this site) know exactly what it is. i couldn't really care less if everybody here thinks it's rice.. because it's my car and i can have it look however i want it to look. though comments are always welcome.. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Sep 4, 2006 - 4:12 PM |
Enthusiast Joined Apr 16, '06 From Jackson, MS Currently Offline Reputation: 0 (0%) |
Looks great man, I wish i could get my little red celi to look like that.
~FlamingCelica -------------------- 94 Red Celica ST
Sep 4, 2006 - 4:55 PM |
Thats pretty clean looking and great install. Good work, I still remember when you didn't really have much on. Now it totally looks different. You know what would be nice, since you have the sides and rear, is the splitters that I have. Good job!!!
Lo-Fi Version | Time is now: November 23rd, 2024 - 2:31 PM |
