> Random Brake Light Problem..., Brake light comes on at random times.
post Sep 8, 2006 - 3:10 AM
sdragon007
Joined Sep 30, '04
Hey all. I've got an issue and I assume it is braking related.
My brake light (on the gauge cluster, the e-brake one "BRAKE") will illuminate at seemingly random times during driving. It started illuminating during hard braking about a month ago and now it comes on at will. I notice that hard turns, hard braking, or even just random driving will induce it to illuminate. Any ideas on the source of the problem? Some answers would be appreciated.
Thanks,
Ed
P.S. Forgot to mention: I have a 96' Celica GT. No ABS. Thanks.
This post has been edited by sdragon007: Sep 8, 2006 - 3:11 AM
post Sep 8, 2006 - 5:43 AM
gizmocars
Joined Mar 16, '06
From vernon, nj
try checking if the wires under the car are loose and check the brakepads for the parking brake
post Sep 8, 2006 - 7:37 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
check your brake fluid level.
post Sep 8, 2006 - 11:54 AM
azian_advanced
Joined Apr 18, '05
From Calgary
isn't there a button switch right beneath the e-brake handle that when pushed (e-brake handle down) the light goes off?
might want to check that out..
post Sep 8, 2006 - 12:28 PM
dubk
Joined Aug 28, '06
From U.S.A.
guaranteed to be brake fluid level. fill it up.
post Sep 8, 2006 - 4:29 PM
jcbass7
Joined Apr 20, '06
From Florida
i agree its most likely brake fluid level. I had a small leak in one line for almost a year until the line finally failed totally. I had to put fluid in about every two weeks. the light came on during hard braking once, and then after a little while came on more often and finally just stayed on.
I had a leak in on of the rear brake lines right where it bends up towards the driverside caliper.
good luck, let us know what it ends up being
post Sep 10, 2006 - 10:55 AM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
yeah its the brake fluid level
1. check it and add some or
2. check your brake pads and see if theyre really worn (thats what it was for me)
-Brian
post Sep 12, 2006 - 1:51 AM
sdragon007
Joined Sep 30, '04
Checked the brake fluid, looks a little low. Filling her up should do the trick.
The bigger question is: do I have a leak and how bad is it?
Hope for the best.
post Sep 12, 2006 - 10:35 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(sdragon007 @ Sep 12, 2006 - 6:51 AM) [snapback]478860[/snapback]
take a look at it? Leaks almost always occure at the connectors or calipers...
Lo-Fi Version Time is now: December 2nd, 2024 - 2:37 PM
