4age vs 7age options |
Sep 8, 2006 - 1:07 PM |
Enthusiast Joined Nov 14, '04 Currently Offline Reputation: 0 (0%) |
Tranny is bad and if im pulling the engine might as well swap out my tired old 7afe. I can't take out the 7a block so keep in mind I'd have to get a second one for a 7age, but here are my options.
4age silvertop 160 hp but overated, supposedly better starting platform then a blacktop 4age blacktop 165hp has lighter internals then silver so revs higher stock, 500 more to start with 7age 16valve 160-200hp? Not easy to build, but parts could be sourced more easily. Need to research how much hp the stock 7a rods can take, but getting forged rods will cost more then a 20valve. Will have more torque in the end. I am leaning towards the blacktop mainly since it is newer and a little more exotic. I could very easily live with 160hp when the swap is done so any of the engines are feasible to me. My long term goal would be 200-250hp at the crank, but that is out of my budget for now and would require a rebuild regardless. I would like to know if the silvertop is really a better starting platform with a blacktop? I have been digging through twincam.org and club4age, but I dont know who's word to trust. |
Sep 8, 2006 - 2:17 PM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
7AGE is doable but the hardest parts are your coolant lines and cam timing
all your options are going to need new harness so they will work both 20v are nice one question is that 200 to 250 horse going to be n/a or force induction -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 8, 2006 - 9:37 PM |
That would be n/a which 200 is a better goal for a 20valve. 7age I have seen make it that high but we are talking a boatload oc ash. Also this is at the crank not the wheels mind you.
I already know I will need a new harness. I would probably have one made for me so I don't risk screwing it up. |
Sep 8, 2006 - 10:31 PM |
Enthusiast Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) |
I would just go with the blacktop 20v 4age over the 20v 7age. I say this because you'll be able to run the ITB's with velocity stacks on the blacktop and you'll be spending alot less when doing the swap. The 7age, from what I read on CLUB4ag, would be difficult to do and cost lots of money. But if money isn't the issue, I would be better off using the funds to upgrade the 20v 4age internals via TODA racing or TOYSPORT. You can replace virtually everything from the inside of the engine, and definitely get that N/A 200+ HP at the flywheel. Somebody did this on CLUB4ag, so you should take a look at it.
This post has been edited by netrata: Sep 8, 2006 - 10:42 PM -------------------- |
Sep 8, 2006 - 10:42 PM |
Id be doing a 16valve 7age if i went the 7a route. The 20valve hasn't been done too much so I am a little more wary of it.
Sep 8, 2006 - 10:59 PM |
Then NIK is the man to talk to since he already did the swap and build, but i'd prefer boosting it like he did since you'll have 4agze parts on the engine IMO.
Lo-Fi Version | Time is now: December 12th, 2024 - 2:37 AM |
