2 Pages V  < 1 2
> Compression Test Results, update: new comp test results
post Sep 25, 2006 - 5:14 PM
there are small plastic clips holding them on...sometimes a small screwdriver will help you pry back the little tab enough to pull the wire off.
post Sep 25, 2006 - 5:35 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
ugh.. is it actually necessary to pull the ignition coil wire out to do the comp test?
my friends tells me no need.. but when i read some comp test thing online.. it tells me to unplug it
06 Civic EX
My For Sale Thread
post Sep 25, 2006 - 7:07 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
all you need to do is...
pull the EFI fuse and take the spark plugs out.
post Sep 25, 2006 - 10:00 PM
elvasoshexai
Joined May 16, '05
QUOTE(Bitter @ Sep 25, 2006 - 8:07 PM) [snapback]483711[/snapback]
06 Civic EX
My For Sale Thread
post Sep 26, 2006 - 5:58 PM
elvasoshexai
Joined May 16, '05
ok i just did the test myself... originally i was planning to do a wet comp test on cyl3...
i let the car warm up.. then drove it around the neighbourhood kinda hard... then parked in my garage... waited about 10min for engine bay to cool down then went to work
i decided to first to a dry myself so i could calculate how much psi it would go up by when i do the wet...
so then i started to do the dry on cyl3... just cranking... didnt step on accelerator... and cranked until needle stopped going up and the # surprised me... then i did a dry on the remaining 3 cylinders... these were the numbers with the dry i did:
1st- 172psi
2nd- 171psi
3rd- 168psi
4th- 172psi
so in the end i didn't bother doing the wet...
not sure y these results are so different than when my mech did it... i'm a bit surprised... because i was holding the guage watching it go up while he cranked the car...
This post has been edited by elvasoshexai: Sep 26, 2006 - 6:48 PM
06 Civic EX
My For Sale Thread
post Sep 26, 2006 - 6:43 PM
Bitter
Joined Mar 11, '06
did he pull all the sparkplugs?
now im worried about #2. run several wet and dry tests back to back, you could have a leak between 2 and 3 in the gasket or something is warped.
This post has been edited by Bitter: Sep 26, 2006 - 6:45 PM
post Sep 26, 2006 - 6:47 PM
elvasoshexai
Joined May 16, '05
QUOTE(Bitter @ Sep 26, 2006 - 7:43 PM) [snapback]484139[/snapback]
oops sorrie.. it's a typo should be 171. my bad.. lemme edit that
06 Civic EX
My For Sale Thread
post Sep 26, 2006 - 7:56 PM
Bitter
Joined Mar 11, '06
hmm, maybe the motor was cold when he ran it or he didnt pull all the plugs out? weird. do a wet test too.
post Sep 28, 2006 - 8:46 PM
Celicaguy13
Joined Sep 9, '05
From Modesto, CA
I tested mine last week. 1995 7a-fe 164k miles.
Comp. 210 across the board.
Leakdown: 5-7%. Healthy engine wink.gif
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 28th, 2024 - 5:53 AM
