> replacing starter, 94 ST hatchback 7AFE engine
post Sep 9, 2006 - 1:06 PM
hagerbk
Joined Sep 9, '06
From texas
Well, I've had some of the same starting problems I've read in the forum. Finally determined it to be the starter. Finally found the starter. Well hidden. Any good suggestations on how to remove and replace the starter? I think it is underneath, removing the passenger drive shaft to get room to reach in and remove. I thought another option would be to remove intake (lots of stuff here) and go from the top. A third option might be to remove hood and reach under intake. I could be missing a trick (going to a mechanic outstanding). Any help would be appreciated.
post Sep 9, 2006 - 1:47 PM
Culpable04
Joined Apr 17, '06
From New Jersey
you can get the starter out without touching any other part of your engine bay.
you have to get underneath the car and loose one bolt them if you have the proper tools you can get to the other bolt from the top. there is a gap between the distribuitor and the engine, with a long socket you can get to the other bolt. that's how I did it not too long ago.
post Sep 9, 2006 - 2:08 PM
hagerbk
Joined Sep 9, '06
From texas
Thanks. will give it a go!
Lo-Fi Version Time is now: December 12th, 2024 - 6:34 AM
