> wiring fogs, i need some help
post Sep 9, 2006 - 2:22 PM
Shigexile
Joined Oct 30, '03
From IL
I'm installing the fogs into my car right now and i came across some problems. So, i need you guy's help if possible.
I'm reading this instructions for this thing and it says i need to attach this wire to the "supply-side wire from the headlight switch to low beam circuit."
I have no clue what this means or what the thing is. I'm sorry, i think its a really simple thing but i have no clue. If you guys can help me out, that will be awesome.
post Sep 9, 2006 - 3:23 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
is this oem fogs?....if so, that should be wired to a relay.....
http://www.6gc.net/forums/index.php?showtopic=38656
post Sep 9, 2006 - 5:41 PM
Shigexile
Joined Oct 30, '03
From IL
mines a 94 fogs....
post Sep 9, 2006 - 10:44 PM
post Sep 9, 2006 - 10:50 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
ok heres what i did (if it helps)...i bought a remote wiring kit w/remote from advance (about $15 or so).....and jus wired it to 3 different grounds...one to the + terminal in the battery and im set.....EASY right?.....
This post has been edited by DeW_H0e_GT: Sep 9, 2006 - 10:51 PM
post Sep 10, 2006 - 12:59 AM
Shigexile
Joined Oct 30, '03
From IL
hmmm. thanks of the helps guys. i did manage to get the fogs in but i'll try the wiring tomorrow. you guys are awesome!
post Sep 12, 2006 - 7:29 AM
klm317
Joined Feb 28, '06
From illinois
i did the same as Hoe just without the remote. all that means is that i have a wire and switch coming into the cockpit. but if you go that rout, they have detailed instructions that make it impossible to mess up. all you have to do for the "acessary" wire is tap into your power for your low beams so that the fogs will go off when you turn on your brights.
Lo-Fi Version Time is now: February 17th, 2025 - 11:00 AM
