![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) ![]() |
QUOTE(chacha @ Sep 14, 2006 - 1:50 AM) [snapback]479580[/snapback] so let me get this right...we can change the high's and make it low...but can we make the high lights for both the low's and high's?...turning the high when you need all four lights to be low's and hence, when in need of the high's change them to be high...turning them on as high beams? (basically, asking if we can have the high set to both high and low beams when needed)...? ![]() -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) ![]() |
hahaaha...good expression azian...now that i was reading it...it doesn't seem to make sense anymore...lol...it was too early in the morning...
What i really meant to say was: Can we make all the headlights (lows and highs) work as low beam headlights, but still manage to press the high beam headlight switch and pop the high headlights back to its original high beam...? if this still doesn't make sense...oh well...guess not... |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '05 From torrance/carson, ca Currently Offline Reputation: 11 (100%) ![]() |
you probably have to install a second set of lights in your high beams if you want them to be both lows and highs. or you can just turn your highs into lows and your fogs into highs.
Lo-Fi Version | Time is now: February 23rd, 2025 - 1:12 PM |
