> Radiator hoses.
post Sep 11, 2006 - 5:14 PM
JaxMadine
Joined Jan 31, '06
Im still doing the 3s swap into a 95 ST, and was wondering how to hook up the radiator hose from the new motor to the ST radiator. Both the inlet and outlet hoses or on the drivers side of the radiator. Do I need a diff radiator? The AWD one wont fit.
This post has been edited by JaxMadine: Sep 11, 2006 - 5:18 PM
post Sep 11, 2006 - 10:39 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
the top one is the stock ST hose, the lower, well i got lucky and found a 1 piece hose (motor to rad) to fit perfect. from autozone.. take a ideal lenght measurement and look at allthe hoses, youll know it when you see it. i may have a part number around. shoot me a pn if u want it. ill dig it out
post Sep 11, 2006 - 10:49 PM
eggman40
Joined Aug 17, '04
From California
i went to home depo and got a 6in long pipe, i dont remember the diameter but i took the radiator hose with me. It was enough to get it to reach the other side of the motor. I also used the worm clamps to prevent leaks. So far not a single issue. Not even rust.
Lo-Fi Version Time is now: February 18th, 2025 - 3:01 PM
