> mass air meter, ?
post Sep 12, 2006 - 3:19 PM
saleeka
Joined Sep 4, '03
From Twin Cities MN
I was trolling around on another forum and stumbled across a post about poor engine performance and drivability linked to something called a mass air meter. It basically said that the mass air meter gets dirty from the oil that is used on performace air filters like K&N, thus resulting in multiple symptoms such as reduced performace, ect. Anybody have any experence with this? I'm particularily curious because I know its time to clean my air filter up, and as of late my car has had greatly reduced performance and overall weird drivability issues, and lo and behold I have an oiled TRD filter... I would assume our car's mass air meter would be located somewhere along the air cleaner box/intake? And any tips on how to "clean' a mass air meter?
post Sep 12, 2006 - 4:25 PM
WALKER
Joined Mar 29, '06
From Regina, SK, Canada
I don't believe that you will have a problem with a MAF sensor on a 5S-FE, because I don't believe we have one!
We have a MAP sensor setup.
If you have swapped to a 3S-GTE then you will have a MAF.
post Sep 12, 2006 - 7:37 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
The MAF can actually be adjusted and tuned. Most people don't realize it, but if u open up the black cover thingy on top if it and have a small flat head scredriver handy, you can regulate how much air is calculated going to the ecu. Via making the flaps harder to open or easier to open.
Lo-Fi Version Time is now: November 28th, 2024 - 11:51 AM
