> euro 3sge engine, T-VIS?
post Sep 12, 2006 - 7:56 PM
Valo666
Joined May 15, '05
From Toronto
So, since ive blown my motor now...hmmm..3 times. Ive been thinkin of what swaps i can do. So theres BEAMS, but thats like $5000 for the motor and a pain in the arse for wiring, plus different mounting angles, 3sgte but gotta do all the wiring + the piping + axels + all the stuff to get boosted. So im thinkin i might get a euro GT spec 3SGE. They are 2.0L, so its a bit beter on gas, but ive seen some 3SGE's have T-VIS. Do european spec motors have T-VIS?? Also, is the engine mounted the same way that a 5s is/could you use 5s factory mounts. Im guessin trans work too because its essentialy the same block as a 3SGTE. Any one wanna gimme a hand with some of this info?? Also any european 6GCers out there have complete harnesses/ECUS??
post Sep 12, 2006 - 8:32 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
A 2nd or 3rd gen 3SGE is a good swap, but it's just as much work as a BEAMS swap.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Sep 12, 2006 - 8:46 PM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
http://www.6gc.net/forums/index.php?showtopic=36288&hl=
Here is some info from an older post on the 3rd gen............also, i belive that u can use the 5s/mounts when swapping engines.....the eurospec (3rd gen)also came with ACIS, not TVIS........
(\__/)
post Sep 12, 2006 - 9:31 PM
Valo666
Joined May 15, '05
From Toronto
QUOTE(Dr_Tweak @ Sep 12, 2006 - 8:32 PM) [snapback]479109[/snapback]
-Doc
doesnt beams sit at a different angle as the 5s though?..i heard its somethin like a 13 degrees. but it should bolt into the 5s mounts right? and tranny should line up right??
Lo-Fi Version Time is now: November 28th, 2024 - 1:36 PM
