Rear suspension hum. |
Sep 13, 2006 - 10:07 AM |
Enthusiast Joined Aug 18, '04 From Silverdale, WA Currently Offline Reputation: 0 (0%) |
For the last month I have been hearing a hum from my rear suspension. It sounds like it was coming from the passenger side so I replaced that side's hub but the hum is still there. Any ideas on what could do this? I thought maybe a bushing or the strut. Any ideas would help I am going to put it up on a lift this weekend so that I can inspect everything but I don't want to start tearing the entire rear suspension apart.
Sep 13, 2006 - 10:10 AM |
did you replace the wheel bearing with the hub? otherwise the wheel bearing might need some more grease
Sep 13, 2006 - 1:49 PM |
I put the one that I bought from you Lewfx on there and everything was fine. I drove to Montana and then over to Washington and on the way to Washington it started to hum. I thought it was the bearing but like I said I replaced it and the hum is still there.
Sep 13, 2006 - 2:22 PM |
how quickly i forget...tire pressue okay?
Sep 13, 2006 - 2:23 PM |
check the alignment, TOE can cause some hard to find noises that sound like bearing humm.
Sep 14, 2006 - 9:52 AM |
QUOTE(Bitter @ Sep 13, 2006 - 12:23 PM) [snapback]479347[/snapback] check the alignment, TOE can cause some hard to find noises that sound like bearing humm. I have no odd tire wear and since it started I have driven about 3k miles. I'm thinking that it might be a strut or a bushing. |
Sep 14, 2006 - 10:21 AM |
id take a looksy but you seem far from torrance.
Sep 14, 2006 - 3:19 PM |
QUOTE(bindertch @ Sep 14, 2006 - 9:52 AM) [snapback]479633[/snapback] QUOTE(Bitter @ Sep 13, 2006 - 12:23 PM) [snapback]479347[/snapback] check the alignment, TOE can cause some hard to find noises that sound like bearing humm. I have no odd tire wear and since it started I have driven about 3k miles. I'm thinking that it might be a strut or a bushing. toe in or toe out can be very hard to feel, just a degree out of specs can cause noise with some tires. -------------------- |
Sep 14, 2006 - 3:24 PM |
strut wont cuz humming.
Lo-Fi Version | Time is now: December 1st, 2024 - 12:49 PM |
