Transmission Question, what else to replace while replacing clutch |
Sep 13, 2006 - 10:42 PM |
Enthusiast Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
my clutch is starting to slip a bit so now i needa save a bit of cash incase one day it goes really bad... so i needa kno what i need to save up for
so i was wondering... if i'm getting my clutch replaced.. what are all the things i should replace while doing it? i notice some places have clutch kits which include pressure plate street disc release bearing alignment tool a clutch kit should have everything i need right? so i think i will most likely buy a clutch kit? but other than those parts in the kit, are there any other parts i should i replace while i'm at it? like: bolts/screws flywheel throw out bearing shift cables master/slave cylinder -------------------- |
Sep 13, 2006 - 10:57 PM |
your flywheel should be checked against specs and cut or replaced if needed.
bolts may or may not be reusable. shift cables should be ok throw out bearing, if its cheap you might as well replace it. master/slave, if its not broke then you dont need to fix it. but DO bleed the old fluid from the system and bleed any air from the system. -------------------- |
Lo-Fi Version | Time is now: November 29th, 2024 - 6:43 AM |
