Toyota Land Cruiser Help! Urgent! Rotor!, taking off the rotor |
Jun 24, 2003 - 9:44 PM |
Enthusiast Joined Apr 20, '03 From Chicago Currently Offline Reputation: 0 (0%) |
Hey guys,
I know this doesn't really really belong here, but I'm in desperate need of help. I'm trying to replace the brake rotor on my friends mom's 96 Land Cruiser, and I seem to have removed everything holding it on - wheel, studs, lock retainer, greese cap. Here's a picture of where we are. What do I do now? The thing is just...on there! HELP! NEED TO GET THIS DONE! |
Jun 24, 2003 - 11:19 PM |
Enthusiast Joined May 17, '03 From Ontario, Canada Currently Offline Reputation: 1 (100%) |
hope I am not too late to help. There should be a threaded hole in the rotor. Find a bolt that is the same thread as the hole. Screw it in and it should force the rotor off. If that does not work, try a hammer since you are replacing the rotor. The rotors tend to rust to the hubs over time.
good luck |
Jun 25, 2003 - 6:04 AM |
Enthusiast Joined Mar 17, '03 From Quebec Currently Offline Reputation: 0 (0%) |
Check the new ones you've got.
See if the brake disc comes with the wheel bearing...if so, you must take off the bearing. If not, well, good luck ! Try to figure it out with the new one shape and all |
Jun 25, 2003 - 4:46 PM |
Thanks geekboy. I'm good now.
Lo-Fi Version | Time is now: November 25th, 2024 - 11:40 AM |
