![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jan 30, '06 From Augusta, GA Currently Offline Reputation: 4 (100%) ![]() |
I hear you can remove the lines in your headlights...is this possible? If so, does anyone know how to do it and could possibly tell me!?
-Triscuit -------------------- 2007 Subaru Impreza WRX STi 1974 Datsun 260Z 1997 Subaru Legacy L Wagon Kind of missin' my Celica GT! Hit me up if you're ever in my area. I'm always down for a meet. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) ![]() |
what do you mean?
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) ![]() |
i think he wants to make a clear lense.
Enthusiast ![]() ![]() ![]() Joined Jul 29, '03 From north of detroit Currently Offline Reputation: 6 (100%) ![]() |
i think he means having the lenses polished smooth...
and the answer, to my knowledge is yes...that it can be done...but it's not cheap and requires that you remove the lenses from your lights. dustin15brown has polished highs...they look great, but he'd be the one to tell you how to get it done....and how much you can expect to pay. -------------------- ![]() do you know who i am, mr. worley? |
expect to pay a few hundred if you can find someone to do it...its glass which has to be sand blasted i do believe and its very hard to convince a shop to do it to DOT glass...but good luck
![]() Enthusiast ![]() ![]() ![]() Joined Nov 12, '02 From Columbus, Ohio Currently Offline Reputation: 15 (100%) ![]() |
I guess the hard part is having the apparatus to do it. The front side has to be cooled with water while being sand blasted.
This post has been edited by celica3sgte: Sep 16, 2006 - 11:40 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) ![]() |
QUOTE(celica3sgte @ Sep 16, 2006 - 9:40 PM) [snapback]480594[/snapback] I guess the hard part is having the apparatus to do it. The front side has to be cooled with water while being sand blasted. Whole glass has to be in water while beeing sanded - or else it will crach just in seconds.. After this special polishing disk has to be uses along with special green polishing paste and bla bla bla.. Dustin lenses where polished here in Lithuania, and his set was the last that the shop did. They said either we will charge inormal money, or we wount do this anymore... -------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Thanks for your help guys! And yeah, basically talking about clear lenses.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '05 From torrance/carson, ca Currently Offline Reputation: 11 (100%) ![]() |
how about removing the frosted lenses and replacing them with plexiglass?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) ![]() |
in order for that to happen, someone must make a mold for the lights lense.... it wil not be cost effective... I found a place in New York a while back to do them.... $300 ish just for the lows...
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) ![]() |
i've seen ths mod done on a camry.. it was easier on it because it had plastic lenses instead of glass like ours. there was a how-to posted on the net somewhere..
QUOTE(dustin15brown @ Sep 17, 2006 - 5:10 PM) [snapback]480818[/snapback] in order for that to happen, someone must make a mold for the lights lense.... it wil not be cost effective... I found a place in New York a while back to do them.... $300 ish just for the lows... that's still cheaper than removing the lines from the stock lenses right. -------------------- |
![]() Enthusiast ![]() Joined Feb 26, '05 From Venezuela Currently Offline Reputation: 0 (0%) ![]() |
no hagas eso!! si quitas esas lineas vas a perder la direccion de la luz, yo lo hice con mi Celica, y me quedo muy clear!! se ve muy nice, pero la funcionabilidad es pesima!! la direccion de la luz cambia por completo! y se te hace muy dificil la vision!!
Mi recomendacion es que no lo hagas... pd. If anyone can translate this please... my english is so bad!! excuse me guys ![]() -------------------- TOYOTA PARKING ONLY all others will be crushed...
![]() P®¡n©iÞ€MB marvi75@hotmail.com SOPHIA & EZEQUIEL are my life!! I love them!! |
you're saying that the lines serve a function, which is to spread the light in the correct pattern to properly illuminate the road, and removing them can make the ligthing pattern poor.
my spanish is a little rusty. -------------------- |
sorry i meant that i found a place to remove the lines... not make a plastic lense or w/e
and yes... it will screw up your beam pattern... it will not spread out like it should... It's ok in my case because I have a projector and HID's ![]() -------------------- ![]() |
QUOTE(Bitter @ Sep 17, 2006 - 8:54 PM) [snapback]480838[/snapback] you're saying that the lines serve a function, which is to spread the light in the correct pattern to properly illuminate the road, and removing them can make the ligthing pattern poor. yess!! exactly!! -------------------- TOYOTA PARKING ONLY all others will be crushed...
Lo-Fi Version | Time is now: February 23rd, 2025 - 8:01 AM |
