FS: CELICA PARTS, Updated with more parts and pics |
Sep 18, 2006 - 4:30 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
I have a pair of redded out stock tails, an axle for a brand new rebuild axle for a gt, 3s ecu, 7a manual ecu, st driverside manual mount, driverside st185 mount, and more. The hubs are not for sale though. Make offers on everything.
This post has been edited by Rjb23: Sep 28, 2006 - 12:49 PM |
Sep 18, 2006 - 4:40 PM |
Enthusiast Joined Jul 9, '04 From Las Vegas USA Currently Offline Reputation: 14 (100%) |
Are they direct fit to our cars (GT)? If so pics please.
Sep 18, 2006 - 6:16 PM |
Enthusiast Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) |
Will these work for a rear conversion for the ST?
-------------------- --------------------------------私は銀行に漂う,TRD Inspired |
Sep 18, 2006 - 6:46 PM |
Im pretty sure they are the front.
What all is apart of what your selling? Just the calipers and pads? or the brakets as well? |
Sep 19, 2006 - 9:39 AM |
Calipers, pads, brackets that bolt to the hub. Basically the only thing you have to do if you have an ST is bolt these up. They are a direct fit. They are for the front.
They will not work for rear conversion, though I do have everything needed for a rear disc conversion if someone makes me a good enough offer I will sell those as well. |
Sep 19, 2006 - 9:58 AM |
Enthusiast Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
QUOTE(Rjb23 @ Sep 19, 2006 - 7:39 AM) [snapback]481343[/snapback] Calipers, pads, brackets that bolt to the hub. Basically the only thing you have to do if you have an ST is bolt these up. They are a direct fit. They are for the front. They will not work for rear conversion, though I do have everything needed for a rear disc conversion if someone makes me a good enough offer I will sell those as well. what app did you use for new pads/rotors? (i understand there used) i need some pads for my clip upgrade but am unsure of the app to look them up with? i want to install mine this weekend! This post has been edited by zipstrips: Sep 19, 2006 - 9:58 AM |
Sep 19, 2006 - 10:15 AM |
Enthusiast Joined Sep 4, '03 From Gardena, South Bay Currently Offline Reputation: 0 (0%) |
what about GT, i have 96 GT will they fit? also do they say celica on the front? and one more Question, if i need to replace the pads what pad do i use?... i was thinking of buying them if they fit my car..
Sep 19, 2006 - 12:26 PM |
I'm not sure if they will fit a gt or not I have an st and they bolted up fine on my car. They come with pads that are brand new and still in the box, they are st165 pads.
Sep 19, 2006 - 12:42 PM |
can you post or PM me pics of the bracket? possibly with a ruler next to it for size comparison? im curious if they'll fit onto my car. if they do, then i might take them from you. is the rotor diameter the same with these calipers?
actually, im pretty sure that i will take them if i can just double check that they'll be a direct bolt on affair. This post has been edited by Bitter: Sep 19, 2006 - 12:56 PM -------------------- |
Sep 19, 2006 - 12:54 PM |
they won't fit on an GT for the same reason you can't use GT calipers on ST cars...
Sep 19, 2006 - 3:29 PM |
QUOTE(Rjb23 @ Sep 19, 2006 - 10:26 AM) [snapback]481389[/snapback] I'm not sure if they will fit a gt or not I have an st and they bolted up fine on my car. They come with pads that are brand new and still in the box, they are st165 pads. so are the st165 or 185 upgrades? or are the same pads used through these years? |
Sep 19, 2006 - 4:22 PM |
They are from an st185, they came off my clip. The american version of the st185 did not have dual piston caliper and the pads are too small. The american version of the st165 did have dual calipers so you have to use those.
Sep 21, 2006 - 9:10 AM |
Everyone pm'd back.
Bump. |
Sep 23, 2006 - 6:36 PM |
Bump for pics.
Sep 23, 2006 - 7:34 PM |
Think you could host those pics elsewhere? 6GC profile photos are intended to show off your car, not for hosting images to sell parts.
Sep 24, 2006 - 8:38 AM |
Enthusiast Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) |
(photo bucket) host images any pics yet???
Sep 24, 2006 - 10:57 AM |
Sorry Coomer pics hosted else where.
Bump. |
Sep 25, 2006 - 1:09 PM |
Bump
Sep 25, 2006 - 1:49 PM |
im still interested in the calipers, but i'd like to see pics and if possible have you measure the hub side of the mounting bracket so i can be sure that they bolt on.
and one more thing, what diameter rotor do the calipers mate with? -------------------- |
Sep 25, 2006 - 6:05 PM |
The rotors are the same size as the st rotors. If you have an st they will bolt right up and you do not have to change hub or rotors.
Here is the post were doggy upgraded his brakes with st165 calipers which are the same as these st185 calipers. http://www.6gc.net/forums/index.php?showto...49&hl=st165 I'll get pics I keep forgeting to take my camera with me to work. This post has been edited by Rjb23: Sep 25, 2006 - 6:07 PM |
Lo-Fi Version | Time is now: November 23rd, 2024 - 4:42 PM |
