> 1st post...low idle problems..help please
post Sep 18, 2006 - 7:44 PM
TurboZo
Joined Sep 18, '06
From Irvine,CA
Hi, glad to find an active forum for the 6 gen celica...
I've had our (my wife's car) 99 GT for 3 years now. Since I've had it, I've been struggling with the low idle problem. On start up, the engine often stalls since the RPMs aren't high enough. At first I used to slightly hold the pedal until it warmed up. After taking the throttle body off, cleaning it, cleaning the ISC, testing it, the cold start worked for a while then started having the problem again. Currently, when starting up, it idles around 450 and feels like it will cut out. Once in a while the idle seems correct though soon it goes back down. with the AC on, at a standstill in D (auto), it starts to chug a bit since the idle is so low. Recently, I gave up and took it to a trustworthy mehcanic...he did a fuel system cleaning along with the intake cleaning. afterwards, the idle worked great...at cold start, the idle went right above 1k then eventually came down to 750...that lasted a whole 3 days...and now it is back to as I mentioned before. This issue has been driving me nuts for 3 years. I'm considering doing the seafoam manuver today.
Other things that may be related:
-some smoke at startup (perhaps aging seals, or pcv valve, or something else?)
-the engine temp stays low for quite a while, not staying at the midway mark like it did before)
Any input would be much appreciated.
Thanks,
Zo
99 GT
145k
auto
post Sep 18, 2006 - 7:50 PM
GreenyST204
Joined Apr 11, '06
From Tasmania
Welcome TurboZo,
This might help
Resetting your Air/Fuel Mixture Ratio
Ok Gladys, lets play house, you be the door and I'll shut you.
post Sep 18, 2006 - 7:53 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
check the engine coolant temp sensor, check the IAC motor, and check the wiring that runs to and from all of those.
post Sep 19, 2006 - 12:46 PM
TurboZo
Joined Sep 18, '06
From Irvine,CA
QUOTE(Bitter @ Sep 18, 2006 - 7:53 PM) [snapback]481179[/snapback]
Thanks for the suggestions. Is there any additional info on the IAC Motor? Does this forum have a link to an online Repair Manual. I've been using the MR2 one (mr2-tech.com)
Thanks,
Zo
post Sep 19, 2006 - 1:52 PM
hitcachi
Joined Jun 19, '05
From Nebraska
QUOTE(TurboZo @ Sep 18, 2006 - 7:44 PM) [snapback]481175[/snapback]
lol. Whats up with alot of the 99 GT's being owned by people wives?
post Sep 19, 2006 - 1:59 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
might be the aic or the o2 sensor.
post Sep 19, 2006 - 2:47 PM
TurboZo
Joined Sep 18, '06
From Irvine,CA
QUOTE(hitcachi @ Sep 19, 2006 - 1:52 PM) [snapback]481415[/snapback]
haha. well for us, my wife originally wanted an eclipse but I said no way since they have such a horrible track record in terms of reliability. I was thinking of the newer celica but my wife said they look too boxy and guy-ish...on the other hand she said the older celicas are curvy and (you guys are going to hate this) feminine. So I got her the last year of that generation.
we really like this car and would love it if it wasn't for this damn idle problem.
-Zo
post Sep 19, 2006 - 2:54 PM
Kadett
Joined Mar 17, '05
From The Netherlands
In my case, Low RPM and almost stalling was caused by a malfunctioning O2 Sensor.
post Sep 19, 2006 - 3:03 PM
TurboZo
Joined Sep 18, '06
From Irvine,CA
QUOTE(Kadett @ Sep 19, 2006 - 2:54 PM) [snapback]481442[/snapback]
which one was it in your case, the one on the exhaust mani or the one further down?
thanks,
zo
post Sep 19, 2006 - 3:13 PM
Kadett
Joined Mar 17, '05
Well the 3S-GE only has one since it has a 4-2-1 exhaust mani. So it was the one further down between exhaust mani and cat. But I think a local garage/dealer can find it out for you.
Lo-Fi Version Time is now: February 22nd, 2025 - 6:33 PM
