Celica 94 GT 5sp /// swap to 3sg ????? |
Sep 21, 2006 - 10:26 AM |
Enthusiast Joined Sep 21, '06 From New York City Currently Offline Reputation: 0 (0%) |
What’s up everyone.
I know there a lot of post in regards to this topic but I am new to this and I don’t seem to find the right info. I have a 94 gt 5 speed hatch. Has anyone done the swap from 5sfe to 3sg. Can I keep my tranny? (Has anyone kept it?) Let’s assume I can find the 3sg engine for about 1500 with ecu and hardness cut. How much more will I need. I am on a tight budget. How about the 4wd tranny form a gt-4. How will that tranny fit a fwd car. Will it fit? If one of you guys have done the swap hit me up with a link to a write up or something that will help me make a better decision. thanks -------------------- |
Sep 21, 2006 - 10:38 AM |
Enthusiast Joined May 23, '06 Currently Offline Reputation: 0 (0%) |
yes you can keep your tranny.
you will need alot more than $1500 the awd tranny will not work. |
Sep 21, 2006 - 10:39 AM |
Enthusiast Joined Oct 3, '02 From HOUSTON Currently Offline Reputation: 0 (0%) |
read the stickies
Sep 21, 2006 - 10:45 AM |
Thanks. I will continue doing research on this site. I am sure to find very good info. -------------------- |
Sep 21, 2006 - 11:05 AM |
Enthusiast Joined Nov 22, '05 From Mesquite, Texas Currently Offline Reputation: 0 (50%) |
Like they said, read the stickeys.
Oh and BTW some guy named celicagt04 is selling his 3sgte motor.. contact him! This post has been edited by CelicaGT04: Sep 21, 2006 - 11:06 AM |
Oct 17, 2006 - 2:29 PM |
Ok The project is on.
I bought the 3sgte 2nd gen motor with 4wd tranny, computer axles, fuel pump, I beleive everthing needed to make the swap. I am still researching little by little. I will continue to post as I progress with the swap. 2nd gen 3sgte deliverd to NYC 1300 -------------------- |
Oct 17, 2006 - 2:37 PM |
Enthusiast Joined Jan 10, '06 From Mozambique, Africa Currently Offline Reputation: 8 (100%) |
Good luck! the more i hear about people doing the swap, the more i'm considering doing the same thing.
-------------------- "Remember, amateurs built the ark and professionals built the Titanic. But revolutionaries built the Celica!"- Me |
Oct 17, 2006 - 4:16 PM |
sounds like an engine set...
did you get all the required accessories along with the motor? harness, ingitor, coil, resistor packs, map sensor afm, ecu, ect...? -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Oct 17, 2006 - 8:14 PM |
QUOTE(presure2 @ Oct 17, 2006 - 4:16 PM) [snapback]492820[/snapback] sounds like an engine set... did you get all the required accessories along with the motor? harness, ingitor, coil, resistor packs, map sensor afm, ecu, ect...? Yes. It seems like I got everthing. I am slowly reading up on the swap. I use the car daily and dont want to start and be without a car for too long. You know something you only live once. It is a hobby, and once its done ...........umnnnn.... I feel sorry for those hondas. I guess i will start by getting a gasket kit, changing water pump and timing belt. I know now that i can use the gt tranny but from what i read it will not hold up too long. I would like to change it to a solara v6 tranny but then there are also complications with the axles and the wires to change the gears. before I do the heart transplant I need to be sure everthing is on the table. Thanks everyone great site. -------------------- |
Oct 17, 2006 - 9:39 PM |
QUOTE I know now that i can use the gt tranny but from what i read it will not hold up too long. this is a big myth. there are a lot of people on this site using that tranny with no problems for years now. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Oct 18, 2006 - 7:51 AM |
QUOTE(lagos @ Oct 17, 2006 - 9:39 PM) [snapback]492964[/snapback] this is a big myth. there are a lot of people on this site using that tranny with no problems for years now. Really. I noticed you also have a 3sgte swap. What tranny do you have? I mean it makes more sense to just keep the tranny I already have. No need to alter anything, axles, mounts and shift wires will fit perfectly. I do drive the car hard. -------------------- |
Oct 18, 2006 - 4:22 PM |
art (lagos) is using the stock GT tranny (s54) and has been for a couple years now with no issues, as have i on my 230+whp 5sfTe setup for over a year, with no issues.
IMO its all about the condition the tranny is in BEFORE you swap. if the tranny grinds or anything like that at all before you swap, plan on having problems down the road. for art, and i, we both had good working trannys to start with, and they both continue to prove reliable for us both. -------------------- Former Team 5SFTE pro member ;)
Lo-Fi Version | Time is now: November 28th, 2024 - 12:37 AM |
