> GT4 Bumper w/ Stock OEM Hood, or OEM style C/F Hood
post Sep 22, 2006 - 10:15 AM
m0dd3d1
Joined Jan 30, '06
From Augusta, GA
So say I wanted this setup. I know that if you have the GT4 Hood and stock bumper there is a gap, but does anyone have a pic of how it looks with just a GT4 Bumper and OEM Hood? Is there a raised gap instead of a lowered gap? Thanks in advance.
-Triscuit
This post has been edited by m0dd3d1: Sep 22, 2006 - 10:37 AM
1998 Toyota Celica GT
2007 Subaru Impreza WRX STi
2007 Toyota Tacoma 4x4
1974 Datsun 260Z
1997 Subaru Legacy L Wagon
post Sep 22, 2006 - 10:20 AM
Negative
Joined Apr 28, '04
From Houston, Texas
Seems like it would make it hard to open the hood/get to the latch. I actually want to do the opposite. I've seen a pic of it and I think it looks kinda cool. The center bulge sort of makes another scoop.
post Sep 22, 2006 - 10:30 AM
Negative
Joined Apr 28, '04
From Houston, Texas
Like so:
http://www.6gc.net/forums/index.php?showtopic=41350
You would have the opposite problem. As I said - seems like it would be hard to get to the latch.
post Sep 22, 2006 - 10:36 AM
m0dd3d1
Joined Jan 30, '06
From Augusta, GA
Unless you have a C/F Hood w/ hood pins...on another note, do all C/F hoods need hood pins & if so, would I be able to have that setup (C/F OEM style hood w/ GT4 Bumper)?
1974 Datsun 260Z
post Sep 22, 2006 - 11:14 AM
hitcachi
Joined Jun 19, '05
From Nebraska
QUOTE(m0dd3d1 @ Sep 22, 2006 - 10:36 AM) [snapback]482611[/snapback]
no
post Sep 22, 2006 - 4:17 PM
l19tly
Joined Jun 15, '06
From newcastle uk
the bumper will sit higher than the hood therefore making it hard to open, if you got a gt4 hood you would also need the gt4 hood latch because of the scoop! i supose you could make it work either way!! theres nowt like a challenge smile.gif
post Sep 22, 2006 - 5:04 PM
urbandork
Joined Jul 16, '04
From Los Angeles
the raised bump on the gt4 bumper will make the oem hood sit on the rasised section. As such ull have a gap on each side of the hump that will look like two scoops and ur hood will not sit flush with the sides of ur fenders. Plus ur latch wont be long enought to engage and will have to be extended
in order to get it to fit ull have sqwish ur gt4 bumper down or cut into it so that way the hood will clear the bumper with out hitting where the bolts to the bumper would normally attact to the radiator suport.
another thing u can do is make vertical cuts next to the scoop on the front of the gt4 bumper and take out the angled/raised areas. use a heat gun to soften it up and make the scoop flush with the rest of the bumper then fiber glass where needed.
This post has been edited by urbandork: Sep 22, 2006 - 5:09 PM
Lo-Fi Version Time is now: December 3rd, 2024 - 3:49 PM
