Removing Spoiler, wtf....not workin |
Sep 22, 2006 - 11:40 AM |
Enthusiast Joined Oct 11, '05 From Ajax, Ontario Currently Offline Reputation: 2 (100%) |
so im trying to install my blocks and im having trouble removing the spoiler, i removed all of the bolts and it still doesnt come off, im assuming theres some type of adhesive holding it to the car still? i pulled and pulled but nothing..anywone have any advice on what to do?
Sep 22, 2006 - 11:52 AM |
Enthusiast Joined Nov 21, '05 From Wpg, MB. Canada Currently Offline Reputation: 3 (100%) |
go search for Asian-Advanced's how-to when he put in his blocks
Sep 22, 2006 - 12:00 PM |
Enthusiast Joined Jun 23, '05 Currently Offline Reputation: 4 (100%) |
when i took mine off for the first time, i used an old credit card and worked around the edges picking and cutting at the adhesive. do that a while, and then just give it a nice pull. afterwards your going to need some goof-off to get off the remaining adhesive.
-------------------- I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Sep 22, 2006 - 12:11 PM |
Enthusiast Joined Dec 9, '05 From Bedford, TX Currently Offline Reputation: 11 (100%) |
I just took mine off yesterday. It has 2 bolts on both side and one in the middle. I notice there is double sided tape once i took it off. you just gotta find something like a knife to cut through the adhesive like celicast did.
-------------------- <--- I miss :'' (
Sep 22, 2006 - 12:35 PM |
QUOTE(Starcraftjunkie @ Sep 22, 2006 - 11:52 AM) [snapback]482634[/snapback] go search for Asian-Advanced's how-to when he put in his blocks well thats what i was following but the problem was that in the how to it said tha they should easily come off ...they didnt>< ok thanks for the help ill go ttry that now -------------------- |
Sep 22, 2006 - 12:55 PM |
they dont come off easily at all. i took off 2 spoiler off of 2 gt's and both wasnt easy to take off. its just the adhesive that is difficult to work with.
Sep 22, 2006 - 10:30 PM |
Enthusiast Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
I took the spoiler off my hatch a couple days ago. it was real easy. I just opened the hatch, removed the two bolts on each side, took off the big plastic piece on the interior of the trunk to remove the other bolt on each side and it came right off! a little dirty underneath, but no there was no adhesive stuff...
-------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Sep 22, 2006 - 11:56 PM |
yeah.. i didn't have any adhesive on mine either... hmmmm
Sep 23, 2006 - 1:11 AM |
Enthusiast Joined Sep 13, '04 From Sydney/Australia Currently Offline Reputation: 2 (100%) |
im guessing the oem 2-post spoiler came without adhesive and the oem 3-post spoiler came with adhesive.
all you need to do is use goo-remover and use a fine fishing line to slowy slice it off... try not using sharp tools since you'll just be damaging the boot -R -------------------- ROM-23L 67 + 76 = 143
"I wasn't pursuing Sephiroth, I was being summoned by him." - Cloud Strife |
Sep 23, 2006 - 1:47 AM |
darn i didnt think it would be so tough to get it off, im trying everything here the damn thing will not budge
Apr 30, 2013 - 7:52 PM |
Enthusiast Joined Oct 17, '10 From Jax. Fl. Currently Offline Reputation: 0 (0%) |
May 1, 2013 - 12:45 AM |
Enthusiast Joined Nov 29, '10 From Lake Havasu City, AZ Currently Offline Reputation: 31 (100%) |
darn i didnt think it would be so tough to get it off, im trying everything here the damn thing will not budge Nader did it ever come off? I'm having the same problem won't come off Holy 7 year necrobump Batman! The spoiler is held down with 2-3 bolts pert side. Can be founder under the trunk plastics. Also super strong double sided foam tape. after you are certain the bolts are all out and there is just the tape- pick a side and give an easy but FIRM tug. should come up after a bit. after one side is off carefully raise the loose side to aid in breaking the bond , CAREFUL not to break the spoiler! -------------------- 6gcHeroes:808hectortimmybatmandiegotigamak |
Lo-Fi Version | Time is now: November 26th, 2024 - 4:37 AM |
