Nut Size, clutch pedal |
Sep 23, 2006 - 1:36 AM |
does anyone know what size nut goes here...
its at the very top if the bracket holding the clutch pedal. when i push the clutch in that moves against the threads and makes a lot of noise. i found a 12mm nut that kind of fits but wont thread all the way. anyone know? -------------------- |
Sep 23, 2006 - 1:56 AM |
Manny... do you remember if you ever put something there in the first place? cause it creaked a little at first but I don't think it was the same thing because Dustin just sprayed everything with lube and it was fine
Sep 23, 2006 - 8:18 AM |
steff,
its more than likley a 12mm 1.25 or 1.50 thread pitch nut. are you sure its rubbing the threads, and its not the collar on the pivot point of the pedal? with the rust that was on the assy, i wouldnt be suprized if that was also contributing to the problem. have D take the whole assy out, and clean the bushings ect. and add that nut when he reinstalls it. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Sep 23, 2006 - 9:34 AM |
i'm pretty sure its just that bolt rubbing. i'll look for a nut that size and see if it fits then go from there. D said he'd take a look at it for me next weekend if it's still causing a problem. Thanks Manny!
Lo-Fi Version | Time is now: November 30th, 2024 - 12:14 PM |
