applying brake lube |
Sep 25, 2006 - 4:20 AM |
Enthusiast Joined Aug 22, '06 From Daygo Currently Offline Reputation: 0 (0%) |
do i have to take the brakes off and apply brake lube? or can i just put it on without even taking off the wheels?
Sep 25, 2006 - 9:22 AM |
what is brake lube?
Sep 25, 2006 - 2:08 PM |
its applied between the pads and caliper and on the caliper bolts and slides. it helps to reduce unwanted noises and keep things moving smoothly. wherever theres metal to metal contact you put it in the drum brakes.
its usually a thick silicone grease, but white lithium can work. generally though, brake quiet works better between the caliper and pad. its usually a bright color and dries rubbery. -------------------- |
Sep 25, 2006 - 11:31 PM |
sooooo..... i take it off?
Sep 25, 2006 - 11:35 PM |
Enthusiast Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
yea. take out the pads, spray the brake quiet or "brake lube" to the BACK of the pad (part that sits against the caliper) let it dry or whatever the stuff says to do (usually it is reinstalled sticky if it is the brake quiet stuff) then put it back in the caliper.
-------------------- Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Sep 26, 2006 - 12:32 AM |
i like using the red-orange stuff from crc. apply on back of pad, wait til it dries, stick back in.
Sep 26, 2006 - 10:30 AM |
i wonder how many people buy the spray can and spray it through the wheels right onto the rotor?
Sep 26, 2006 - 12:22 PM |
thats the last time i buy metallic brakes
Sep 26, 2006 - 1:01 PM |
why? i love my ferro-carbon hawk HPS pads! they bite great, they dust alot too...but i could care less.
Sep 26, 2006 - 1:49 PM |
Enthusiast Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) |
I also use CRC ..it works great
-------------------- --------------------------------私は銀行に漂う,TRD Inspired |
Sep 26, 2006 - 6:10 PM |
its ****in embarrassing pulling up at a light with a loud ass system thumpin and then u can STILL hear the brakes.
Sep 26, 2006 - 9:18 PM |
are you sure theres not a stone trapped in the pad? try rebedding the pads.
Sep 27, 2006 - 12:42 AM |
theyre brand new... or they were... i had em on, they sounded great, but the next day they started squeaking like ****. its not just one of the brakes either... before my friend put them on for me, he was like "if anything happens to em ill buy u new ones myself..." and after that happened he was like... well thats normal with metallic pads.
Sep 27, 2006 - 1:06 AM |
LOL, thats not normal. did you bed them in properly? did you remove the old pad film from the rotor? if the rotors were new, did you clean the oil off of them?
This post has been edited by Bitter: Sep 27, 2006 - 1:07 AM -------------------- |
Sep 27, 2006 - 9:31 PM |
yeah i rubbed the rotors down with alcohol... he was the one that put them in, so im not positive...
Sep 28, 2006 - 12:31 PM |
did you bed the pads properly and check the pads for any peices of metal or debris?
Sep 28, 2006 - 8:44 PM |
well i didnt but my friend is the one that did that... he said the noise is from the rotors because theyre from napa or some **** like that...
Sep 28, 2006 - 9:25 PM |
make 10-12 stops from 20-5, 30-10, 40-10, 50-10 with 3 minute cool downs bewteen each stop. see if that clears up the noise.
Sep 30, 2006 - 4:50 AM |
ive been drivin around with this noise for about a month now and its still there, i doubt its going to go away
Sep 30, 2006 - 2:55 PM |
you'd be surprised what properly bedding the pads can do to make noises go away.
Lo-Fi Version | Time is now: December 2nd, 2024 - 2:27 PM |
