air bag light..., air bag light... |
Sep 27, 2006 - 4:46 AM |
Enthusiast Joined Jul 21, '04 From Fresno, CA Currently Offline Reputation: 1 (100%) |
my air bag light pop up all of a sudden so what should i do? is there any way to kill the light or see what the problem is like a dianostic test or something? or do i have to go to the shop to turn the light off?
Sep 27, 2006 - 7:34 AM |
The ABS has it's own ABS ECU and if there is a prob with the system (sensor or whatever) it shuts the system down and you have normal braking ability and the ABS light will remain illuminated. You can then read the ABS codes
94-95 ignition in the ON position, bridge E1 & TC in the diagnostics box, just like checking codes, read the code from the ABS light codes 31-34 are the sensors @ each wheel. 31 Malfunction of right front wheel speed sensor signal. Check speed sensor, sensor rotor, wiring harness and connector 32 Malfunction of left front wheel speed sensor signal. Check speed sensor, sensor rotor, wiring harness and connector 33 Malfunction of right rear wheel speed sensor signal. Check speed sensor, sensor rotor, wiring harness and connector 34 Malfunction of left rear wheel speed sensor signal. Check speed sensor, sensor rotor, wiring harness, and connector -------------------- |
Sep 27, 2006 - 8:53 AM |
Enthusiast Joined Jun 14, '05 From colorado Currently Offline Reputation: 0 (0%) |
for the air bag light your need the scan tool to pull codes.
Sep 27, 2006 - 11:18 AM |
you have a 97 correct?
you need an OBDII scanner. depending on the scanner you get it'll either just give you a code which you'll have to look up or it'll tell you exactly what the problem is. some OBDII's allow you to clear CEL's so maybe its the same for the airbag light -------------------- |
Sep 27, 2006 - 11:32 AM |
Enthusiast Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) |
Advance auto parts should let you use there's for free....at least they do by my house
This post has been edited by Daftboy: Sep 27, 2006 - 11:33 AM -------------------- --------------------------------私は銀行に漂う,TRD Inspired |
Sep 28, 2006 - 5:55 PM |
thanx guys...ill see what i can do.
Lo-Fi Version | Time is now: November 27th, 2024 - 11:54 PM |
