choose rite clutch.... |
Oct 2, 2006 - 8:34 AM |
Enthusiast Joined Aug 25, '06 From HAMILTON NJ Currently Offline Reputation: 1 (100%) |
im puttin in my 3sgte and im using the 5sfe tranny and tring to figure out witch clutch for me to use or wat nott... any1 have suggestions on how to go about doin this...
Nov 7, 2006 - 7:30 PM |
Enthusiast Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
Im in the same boat as you. I want a clutch that will hold up to the x-tra hp.
Nov 7, 2006 - 9:35 PM |
Enthusiast Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
use the spec stage 1 or 2 clutch! ITS THE ONLY WAY TO GO!!!
lol just kiddin. go ACT man stage 2, works for me -------------------- |
Nov 7, 2006 - 9:42 PM |
Enthusiast Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) |
Anything thats not stock. HAHA
Stage 2 or 3 are fine. You can go with ACT, Centerforce, Exedy... etc http://www.autopartswarehouse.com/performa...&partid=137 thats where I got mine. Just make sure it comes with everything to do a clutch job lol.. mine didnt come with an alignment tool.. good thing I had one for the 4AGE This post has been edited by jdg371: Nov 7, 2006 - 9:44 PM |
Nov 28, 2006 - 1:44 PM |
QUOTE(easternpiro1 @ Nov 7, 2006 - 9:35 PM) [snapback]500421[/snapback] use the spec stage 1 or 2 clutch! ITS THE ONLY WAY TO GO!!! lol just kiddin. go ACT man stage 2, works for me Im not sure how to tell the difference between stage 1-2-3. Do you have a part# for the act stage 2? Is it ok for a daily driver? I need a clutch soon. Thanks! |
Nov 29, 2006 - 1:41 PM |
Enthusiast Joined Apr 25, '05 From nyc Currently Offline Reputation: 4 (100%) |
grip fource stage 3 works for me. pulls every gear like it wasd 1st
Nov 29, 2006 - 1:55 PM |
Hey,
Has anyone had any problems with using an oem toyota 5s-fe clutch disc and the rest high performance or oem for the 3sgte? I dont want a full racing clutch because this is my daily driver. Ive been talking to ACT and they can only go stock organic or full racing 6 puck with no sprung hub. Im so confused. Im about to say screw it and get a clutch from toyota. Ive got a trd pressure plate that came with the motor. What should I do?????????? This is my daily driver......Thanks!!!!!!!!!!!!!!!!!! |
Nov 29, 2006 - 2:20 PM |
Enthusiast Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) |
The Spec Stage II that Dr. Tweak put in with my swap is holding together marvelously. Chirp Third anyone??
Nov 30, 2006 - 1:29 AM |
Enthusiast Joined Oct 5, '06 From dallas tx. Currently Offline Reputation: 2 (100%) |
im about to upgrade my clutch from stock.... been having some problems with it and from what i know about clutches is after market or racing clutches are way better to get then stock cause you will have to change the stock one out sooner and if you got a any kind of racing clutch as long as you dont race it you should be fine and it will give you that exrta pull if you want to race or if your just trying to pass someone very quickly im not saying that im an expert on all that but thats me.... my car is my dayly driver as well i also and im thinking of going to stage 2 or 3 ....and had a honda single cam that had a stage 4 clutch and it ran just fine just thought i would put in my input think about it....
Nov 30, 2006 - 1:34 AM |
Enthusiast Joined Jun 25, '06 From Bremerton, Washington Currently Offline Reputation: 1 (100%) |
i just bought a new clutch set its a duralast
Nov 30, 2006 - 2:03 AM |
Enthusiast Joined May 3, '06 From New Hampshire Currently Offline Reputation: 2 (100%) |
QUOTE(Fastbird @ Nov 29, 2006 - 2:20 PM) [snapback]506363[/snapback] Chirp Third anyone?? ugh jealous! -------------------- Darin H. |
Lo-Fi Version | Time is now: December 9th, 2024 - 12:29 AM |
