> Head unit help, wiring the head unit
post Oct 7, 2006 - 11:20 AM
bdweber3
Joined Sep 12, '06
From Telford PA
if there is anyone out there that knows of a site that has the factory map of the wiring diagram for the head unit. or if anyone knows the wiring cominations of the head unit connector. i was popping in a new head unit the other day and was blocked by the connector pins not meshing. ive done this process before but with a paseo numerous times but now im on a celica. i am going from a toyota to a sony. if anyone could help it would be much help. thanks bryan
post Oct 7, 2006 - 11:45 AM
SHRiNE
Joined Sep 14, '06
From Daytona,FL
Arnt the wires color coded?
post Oct 7, 2006 - 3:06 PM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
http://installdr.com/Harnesses/Toyota-Wiring.pdf
Get a wiring harness though, from like walmart or any place that sells audio equipment.
post Oct 7, 2006 - 3:53 PM
bdweber3
Joined Sep 12, '06
From Telford PA
the wires are colored. but the connector is a competly different connector then the one i had going into the paseo. if i go to walmart and get a new harness will it work (colors working out)?
post Oct 7, 2006 - 4:17 PM
SHRiNE
Joined Sep 14, '06
From Daytona,FL
QUOTE(bdweber3 @ Oct 7, 2006 - 3:53 PM) [snapback]488873[/snapback]
Yeah, it will..just make sure to get the one for your car. I got mine from there and sometimes you might have to mess with the wires, like if it doesnt work when you put the same colors together(which they should) but mine didnt..I had to put my yellow and red wires together for some reason, but mines a pioneer. So you shouldnt have any problems.
post Oct 7, 2006 - 11:33 PM
bdweber3
Joined Sep 12, '06
From Telford PA
well il head there tom to check that out. if that doesnt work the comute to college will blow big time. thanks for the help guys. u guys rock!
post Oct 8, 2006 - 12:24 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
sometimes driving in silence is good.
most harnesses include an instruction page which lists what headunit pigtail wire color goes to what wire color on the harness side. its just a matter of soldering and heat wrapping it all together. its pretty easy, and shouldnt take more than an hour. i do mine while i'm watching tv or talking to someone so it doesnt get too boring.
post Oct 8, 2006 - 8:42 PM
bdweber3
Joined Sep 12, '06
From Telford PA
hey guys i ended up buying one of the "scosche" harness from walmart today and got it all hooked up and plugged the one end into my sony and when i went to plug the male end into the female end of the factory plug it didnt fit. the plugs are still the wrong size. the one that i used was the TA021, which when i double checked the internet information to the booklet in walmart it said it would fit.... but it doesnt. mad.gif kindasad.gif
Shrine do you remember by chance which walmart plug you used?
This post has been edited by bdweber3: Oct 8, 2006 - 8:43 PM
post Oct 8, 2006 - 9:15 PM
kcizzle
Joined Jul 12, '06
QUOTE(bdweber3 @ Oct 8, 2006 - 8:42 PM) [snapback]489216[/snapback]
I just bought a pioneer head unit that that came with Scoche TA02B for Toyota 1987-up. I haven't installed it yet but I'm planning to install it myself.
post Oct 9, 2006 - 7:11 AM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
You more than likely need to bypass the factory amp, the wiring harness you are using is probably the wrong one. When I get home, I'll take and post some pictures for you and anyone else for future reference to show how I hooked it up correctly. Though I'm pretty sure this has been posted before.
post Oct 9, 2006 - 7:23 AM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
QUOTE(bdweber3 @ Oct 8, 2006 - 9:42 PM) [snapback]489216[/snapback]
The 87+ Toyota wiring harness is the one you need. One like this- http://www.crutchfield.com/S-ErgBDET0bOs/c...amp;i=120701761
post Oct 9, 2006 - 11:08 AM
bdweber3
Joined Sep 12, '06
From Telford PA
well i was at class today and was on a break so i decided to work on my car til the next class. i ended up finding a way to get power to the sterio, i disconnected the amp thats under the head unit and using the two cables that connected to the new adaptor that i bought at walmart that has the plugs of this website http://www.crutchfield.com/S-ErgBDET0bOs/c...amp;i=120701761. its a temperary fix but it seems to work.
what confused me was that when the wires come out of the amp they make one plug that didnt fit any connector that i have seen at all. (kinda gay if you ask me) but the plugs going into the amp are the ones that were compatible so now i have a usless amp until i find a new cable system. any ideas anyone? if you have pix of how you did it (got the amp included and wired so it fits, please post b/c they will be of much use.
thanks, bryan
when i get home from class today il post a pic of what the single cable looks like (the wires that are comming out of the amp to the factorys head unit
This post has been edited by bdweber3: Oct 9, 2006 - 11:12 AM
post Oct 10, 2006 - 4:02 PM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
If the connectors were under the stock amp and were blue then you are using the correct ones. The single plug you are talking about is proprietary to the deck and comes off of the stock amp. There is no wiring harness for this.
I was stumped for a bit at first when I took out my stock deck and saw one plug that didn't match my wiring harness, but then I read on these forums where the correct wires were and now there's no prob! (Except finding the time during the day to get the isntall done)
post Oct 10, 2006 - 6:03 PM
bdweber3
Joined Sep 12, '06
From Telford PA
this may sound like a stupid question but when i took the plugs from the amp the tweeter/dome speekers dont work now. does the amp that i disconnected and redirected to the head unit power those speekers? do you have the tweeter/dome speekers in your car? are they working after you swapped the head units?
post Oct 10, 2006 - 6:11 PM
Sinyk
Joined Oct 4, '06
Well now, I haven't had the time to get my deck in, I've just done the research kindasad.gif I had the deck ready to install and then I had a few questions regarding the amp, so I stopped.
Though you raise a good question and it was one I have as well. With the 6 speakers up front, and with bypassing the stock amp, I assume all of my speakers won't work, right?
I heard some people talk about an amplifier integration wiring harness and connecting the tweeters using RCA cables, but I wanted to know if this was the actual solution to getting all 6 speakers up front working properly, or something else?
What speakers work when you plug in the wiring harness out of the 8 speaker system? I assume the rear 2, but which ones of the 6 up front?
post Oct 11, 2006 - 9:19 AM
bdweber3
Joined Sep 12, '06
From Telford PA
sinyk do you know of anything on the market that would work to get all 6 speekers working (the harness) or is it just a myth.
post Oct 11, 2006 - 11:15 AM
azian_advanced
Joined Apr 18, '05
From Calgary
this was posted a while back, luckily i did a search and found what you're looking for:
http://www.6gc.net/forums/index.php?showtopic=9930&hl=
i've done numerous searches before and some of the details were still quite vague..
but to sum it all up, if you want to keep using your stock amplifiers, you'll need an unamplified signal out of the aftermarket deck you're installing (usually as RCA plugs for output audio at the back of the deck) to mate with the amplifier integration harness. i've already bought mine, the link is in the link above. here's how it should look like.
Metra 70-8112 Premium Amplifier Integration Harness
i'm assuming the rca cables plug into the rca outputs on the back of the deck, these btw are unamplified audio signals. there are two sets, black & white and purple&green. one pair for the front audio signals, the other for the rear.
the rest of the wires hook up to the harness of the aftermarket deck for power, ground, antenna, etc.
a diagram can be download here:
Metra 70-8112 Installation Instructions
the male end of the Metra harness plugs into the original wire harness connector from the amp to the factory stereo.(below)
i hope that just about clarifies everything...
this is what i've found after undergoing some research, but if any of it stands incorrect, pls post.
This post has been edited by azian_advanced: Oct 11, 2006 - 11:18 AM
post Oct 11, 2006 - 1:25 PM
Sinyk
Joined Oct 4, '06
This weekend i'm going to play around with my stereo and such, so I'll let you know what I find as I have fun biggrin.gif
azian_advanced: great pics there. I have a stanard Scoshe harness right now, and I doubt it will be exactly what i need, but i'm still going to play around with it.
This post has been edited by Sinyk: Oct 11, 2006 - 1:26 PM
post Oct 11, 2006 - 11:03 PM
bdweber3
Joined Sep 12, '06
From Telford PA
azian_advanced: in the picture that you posted is there a name for the cable that you marked as "leads to speekers, do not unplug" thats the cable i am looking for. the cable that you sent me too looks different for some reason. kindasad.gif
also does anyone out there know of anyone selling or can get a cable as marked in the picture above as "this connector" my friend came to me and is looking for one so im tryin to help a brother out. biggrin.gif
thanks bryan
This post has been edited by bdweber3: Oct 11, 2006 - 11:04 PM
post Oct 12, 2006 - 3:17 AM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE(bdweber3 @ Oct 11, 2006 - 11:03 PM) [snapback]490556[/snapback]
thanks bryan
the cable marked as "this connector" in the pic above is proprietary to the factory stereo as mentioned. for this cable, your best bet is probably to ask the dealer for it. unfortunately, the parts catalog i have is all jdm and my U.S. parts book doesn't even include this.. you may want to check your local wrecking yards as it seems this harness is used on multiple premium audio setups from 92-97 Toyotas like in 4Runners, Camry, and some Lexus models (GS300, etc).
the cable that's marked "leads to speakers" i'm assuming should have been there in the first place if you were using the stock amp. without it, i'm not even sure how your system even worked. but maybe you can ask a few members parting out their cars for that cable or perhaps start a WTB thread for this wire.
also if the jdm radio wire is the same as yours, here are the part numbers:
this is if your factory radio has the two outlets... not sure if this may be of any help though.
Lo-Fi Version Time is now: February 20th, 2025 - 3:35 AM
