> Head unit help, wiring the head unit
post Oct 7, 2006 - 11:20 AM
bdweber3
Joined Sep 12, '06
From Telford PA
if there is anyone out there that knows of a site that has the factory map of the wiring diagram for the head unit. or if anyone knows the wiring cominations of the head unit connector. i was popping in a new head unit the other day and was blocked by the connector pins not meshing. ive done this process before but with a paseo numerous times but now im on a celica. i am going from a toyota to a sony. if anyone could help it would be much help. thanks bryan
- bdweber3   Head unit help   Oct 7, 2006 - 11:20 AM
- - SHRiNE   Arnt the wires color coded?   Oct 7, 2006 - 11:45 AM
- - AMCMoe   http://installdr.com/Harnesses/Toyota-Wiring.pdf ...   Oct 7, 2006 - 3:06 PM
- - bdweber3   the wires are colored. but the connector is a comp...   Oct 7, 2006 - 3:53 PM
|- - SHRiNE   QUOTE(bdweber3 @ Oct 7, 2006 - 3:53 ...   Oct 7, 2006 - 4:17 PM
- - bdweber3   well il head there tom to check that out. if that ...   Oct 7, 2006 - 11:33 PM
- - Bitter   sometimes driving in silence is good. most harnes...   Oct 8, 2006 - 12:24 PM
- - bdweber3   hey guys i ended up buying one of the "scosch...   Oct 8, 2006 - 8:42 PM
|- - kcizzle   QUOTE(bdweber3 @ Oct 8, 2006 - 8:42 ...   Oct 8, 2006 - 9:15 PM
|- - AMCMoe   QUOTE(bdweber3 @ Oct 8, 2006 - 9:42 ...   Oct 9, 2006 - 7:23 AM
- - AMCMoe   You more than likely need to bypass the factory am...   Oct 9, 2006 - 7:11 AM
- - bdweber3   well i was at class today and was on a break so i ...   Oct 9, 2006 - 11:08 AM
- - Sinyk   If the connectors were under the stock amp and wer...   Oct 10, 2006 - 4:02 PM
- - bdweber3   this may sound like a stupid question but when i t...   Oct 10, 2006 - 6:03 PM
- - Sinyk   Well now, I haven't had the time to get my dec...   Oct 10, 2006 - 6:11 PM
- - bdweber3   sinyk do you know of anything on the market that w...   Oct 11, 2006 - 9:19 AM
- - azian_advanced   this was posted a while back, luckily i did a sear...   Oct 11, 2006 - 11:15 AM
- - Sinyk   This weekend i'm going to play around with my ...   Oct 11, 2006 - 1:25 PM
- - bdweber3   azian_advanced: in the picture that you posted is ...   Oct 11, 2006 - 11:03 PM
|- - azian_advanced   QUOTE(bdweber3 @ Oct 11, 2006 - 11:0...   Oct 12, 2006 - 3:17 AM
- - nightrider   best to use the power cables and harness, but forg...   Oct 14, 2006 - 9:32 AM
- - bdweber3   im kinda lost on the way you worded that entry cou...   Oct 16, 2006 - 9:55 PM
- - nightrider   Yes, Tweeters are connected to the door speakers b...   Oct 25, 2006 - 12:27 PM
- - Sinyk   So I finally got around to playing with my deck an...   Nov 11, 2006 - 8:03 PM
- - azian_advanced   whoa... this got me all worried now.. i will be in...   Nov 12, 2006 - 12:25 AM
- - Sinyk   With the Eclipse head unit harness unplugged from ...   Nov 12, 2006 - 3:45 AM
- - Sinyk   Well it's all done. I ended up bypassing the...   Nov 12, 2006 - 8:53 PM
|- - azian_advanced   QUOTE(Sinyk @ Nov 12, 2006 - 7:53 PM...   Nov 16, 2006 - 8:25 PM
- - Bbuck35   NOT bad .. i just put a 7" pop out LCD but fo...   Nov 16, 2006 - 4:35 PM
Lo-Fi Version Time is now: July 29th, 2026 - 3:03 AM
