![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
I was at the junkyard today browsing for something new for one of my cars, and I came across some trucks, which got me thinking about some comments some members had made a while back about using some 4WD Toyota four-piston calipers on the front of a sixth gen. Celica.
Some interesting facts:
In the end, this conversion may be possible, but I'm not going to be the one to try it. You'd have to drill and tap at least one additional hole in your hub/spindle to get the caliper bracket to bolt up. At that point, you'd probably want to try a ST185 rotor or a similar large-diameter vented 5x100 rotor that's closer to 18mm thick, which may be too thick for the caliper, or too large/small of a diameter for the four-piston caliper. Then there's the issue of the caliper being in the right place for the rotor to slide into place. While spacers could help and probably solve the problem if the caliper is out too far, if it's in too far, you'd be in for a lot of fabrication work. Then you'd have to figure out brake lines, though I have a feeling the truck's lines could be used if modified properly. But if someone wants to try, it may be worth it in the end. You may be better off getting ST205 four-piston calipers, but those are much harder to come by and more expensive, and they require some modification as well I believe, though not as much. Four-piston calipers can be found on several Toyota 4Runners and trucks with 4WD and V6 engines, and probably more Toyotas. I found four-piston calipers on a '95 truck with 4WD and a V6 and on a '88 4Runner with 4WD and a V6 also. The junkyard wanted $25.00 per caliper had I bought them. Just figured you guys might want to know. Post up if you've got any more information or questions. ![]() -------------------- New Toyota project coming soon...
rotors arent an issue at all, just get the specs you need and contact Stoptech, they should be able to get you a part number for the correct rotor or make a pair for you.
![]() Enthusiast ![]() Joined Jun 14, '05 From colorado Currently Offline Reputation: 0 (0%) ![]() |
i was thinking about this too, and next week i'll have a set off of an 06 tundra i was just put my car in the air and see how far off the mounting holes are.
![]() Enthusiast ![]() ![]() ![]() Joined Jul 9, '04 From Las Vegas USA Currently Offline Reputation: 14 (100%) ![]() |
Yeah when I added cross drilled rotors to my 4runner, I thought it was kinda funny that it had a better caliper than my Celica. I never thought to see if they are interchanable.
![]() Enthusiast ![]() ![]() ![]() Joined Feb 3, '05 From Tampa, Florida Currently Offline Reputation: 2 (100%) ![]() |
well even if they work for sure, would the braking power be noticeable?
-------------------- I'am Reinventing the SLow Lane.....
also keep in mind that this 4 pot caliper may need a larger fluid displacement than your master cylinder can provide.
QUOTE(coldbluesteel @ Oct 8, 2006 - 6:08 PM) [snapback]489196[/snapback] Yeah when I added cross drilled rotors to my 4runner, I thought it was kinda funny that it had a better caliper than my Celica. I never thought to see if they are interchanable. It makes sense, considering the 4Runner is much, much heavier than our Celicas. ![]() QUOTE(celica47 @ Oct 8, 2006 - 6:13 PM) [snapback]489200[/snapback] well even if they work for sure, would the braking power be noticeable? I would think so, but again, I'm not sure. QUOTE(Bitter @ Oct 8, 2006 - 6:39 PM) [snapback]489214[/snapback] also keep in mind that this 4 pot caliper may need a larger fluid displacement than your master cylinder can provide. I thought about that, and after reading this and this, the master cylinders weren't replaced with different units in either case, and in both cases there are no complaints. Though both of those cars used two-piston calipers initially I believe, so yes, we may need a bigger-bore master cylinder. Not sure though. -------------------- New Toyota project coming soon...
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 27, '03 From Nor Cal Currently Offline Reputation: 0 (0%) ![]() |
My only complaint with the truck's 4 pot calipers... they're built for much thinner rotors. Because the rotors are thinner... it'll affect cooling more than anything else. IMO... if you're gonna go through the trouble... ST205 calipers or even mkiv Supra calipers are more worthwhile. Truck calipers are cheaper and more plentiful... however. I haven't really had a good look at the newer calipers on the bigger trucks either (tundras, sequoia, and landcruiser)... but they are different and might be much thicker.
-------------------- "It's ok to be naked girl... I'm an artist!"
i know the tundra's and the sequoia's have 318mm x 28mm rotors
coomer, an easy way to check this is to CC the stock caliper at rest and at fully extended (pull it out with something) and then find the difference, this is how much fluid the master cylinder will ever have to move to put it all the way out there. then do the same with the 4 pot. you can just do one side at a time tho or one pot at a time, just be careful with the math as it could get a little tricky keeping track of 4 displacements. if the displacement of the stock is close to the displacement of the 4 pot then it shouldnt be a problem. if its alot more then you'll get low pressure in the 4 pot calipers at max pedal stroke and probably be locking the rear brakes before the fronts can bite. to fix that you could try swapping a truck master on over....but then you have to do something about the rear brakes, what does the donor truck have out back? is that fluid displacement near what your stock rear brakes need?
Lo-Fi Version | Time is now: February 13th, 2025 - 6:21 PM |
