Enthusiast ![]() ![]() Joined Apr 24, '04 From S. Cali Currently Offline Reputation: 0 (0%) ![]() |
Im looking at set of Enkei ES Tarmac Wheels, and the only offset they have for a 16x8 is +45. Will an 8 inch wide rim with that offset cause any problems??
Thanks |
thats going to be sticking in an awful lot. i suspect that you may have clearance issues with the suspension, however someone else here should be able to give a more definate answer.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) ![]() |
maybe the wheel offset guide will help
I did check it, but its says ideal is 40mm. What will the 45 do on a lowered car. What worries me is that it will rub when i try to turn.
Lo-Fi Version | Time is now: February 22nd, 2025 - 6:34 PM |
