![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) ![]() |
Injectors !
just let me know if I can use this for a 7AFTE set-up ? This post has been edited by Culpable04: Oct 9, 2006 - 10:08 AM -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(Culpable04 @ Oct 8, 2006 - 7:50 PM) [snapback]489189[/snapback] i think they will work ,but you may have to change the impendence to high maybe i am not 100 percent sure ![]() -------------------- ![]() |
^ thanks
does anyone have the specs for the stock 7AFE injectors ? I've been searching the net without luck, I know these fit but I still don't know if I have to change the impendence to high. Nippon Denso CC per minute 315 color light green Ohms 13.8 lbs per hour 30.9 Est. hp. each 63.0 Test Press. kPa 290 Toyota 7MGE -------------------- ![]() |
the stock injector rating is 180cc i am not sure of the ohms rating it should be in a haynes manuel
Lo-Fi Version | Time is now: February 23rd, 2025 - 6:22 AM |
