> Setting up my custom 3 in exhaust, couple questions i have before i order anything..
post Oct 10, 2006 - 11:48 AM
jcbass7
Joined Apr 20, '06
From Florida
As some may know i am just about finished with my 3s swap (knock on wood) and soon I'm going to put on a custom 3 in exhaust, keeping the stock DP for now..
flex pipe and tubing
6 inch flex pipe or 8?
also should all of my tubing be stainless or will it not matter if i get aluminzed steel? (i dont care so much about show, but i dont want it to rust out in a week...)
^any ideas about that stuff? what mandrel bends do i need? and how much straight pipe do i need?
Resonator
Magnaflow Resanator
cat
MagnaFlow HF Metallic Spun Converter - 59959 (will buy it soon)
muffler
Magnaflow Race Series 14835
Ok so i found what converter and muffler im getting, but i still need a bit of guidance on what to do for the rest...
This post has been edited by jcbass7: Oct 18, 2006 - 9:11 AM
post Oct 10, 2006 - 12:29 PM
Rjb23
Joined Feb 8, '04
From KY
Run the stock DP for now until you can afford a good one. I run 3" all the way back no cat, no resonator and just a muffler. Not sure what my flex pipe is though.
post Oct 10, 2006 - 12:35 PM
jcbass7
Joined Apr 20, '06
From Florida
is the stock dp 3in? will this matter any?
i was just going to snag a flex pipe from ebay or something like that.. but wasn't sure if i should do everything in stainless or aluminized steel
Mandrel SS Tubing
Stainless Tubing
SS 3x8 Flex Pipe
I was thinking of something along those lines^?
This post has been edited by jcbass7: Oct 10, 2006 - 12:40 PM
post Oct 11, 2006 - 7:05 AM
JDM_ST205_WRC
Joined Oct 6, '06
From UK
QUOTE(jcbass7 @ Oct 10, 2006 - 12:35 PM) [snapback]489930[/snapback]
3S-GTE is 2.5" OEM/Stock
If you’re running a CT20b you will get major boost creep running a full 3" system, unless you get the dual wastegate port machined out to one port.
post Oct 11, 2006 - 5:22 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(JDM_ST205_WRC @ Oct 11, 2006 - 7:05 AM) [snapback]490234[/snapback]
I'm rocking the stock CT-26
post Oct 17, 2006 - 9:09 AM
jcbass7
Joined Apr 20, '06
From Florida
well i bought the muffler,
I got a Magnaflow race series 14835
Next up is the cat, any good high flow cats out there?
post Oct 17, 2006 - 10:00 AM
Culpable04
Joined Apr 17, '06
From New Jersey
check www.horsepowerfreaks.com they have a good selection of high flow cat. make sure you get a metalic on NOT ceramic.
post Oct 17, 2006 - 1:53 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(Culpable04 @ Oct 17, 2006 - 10:00 AM) [snapback]492647[/snapback]
That site has some good stuff..
I decided on this:
any ideas about a resonator?
post Oct 17, 2006 - 2:33 PM
Culpable04
Joined Apr 17, '06
From New Jersey
^^ I think they have the same catalitic with some kind of built in resonator. I'm not sure.
post Oct 18, 2006 - 9:12 AM
jcbass7
Joined Apr 20, '06
From Florida
ok i have most of it figured out, all i need still is the piping, flex pipe and mandral bends.. what should i order?
Lo-Fi Version Time is now: November 27th, 2024 - 8:47 PM
