> 15A tail light fuse keeps popping
post Oct 10, 2006 - 3:04 PM
CCCP
Joined Mar 22, '03
From NH, USA
My tail lights burnt out on me a bit ago then I replaced the bulbs and the fuse and it worked for a while.
Now it has happened again and when I replace the 15A fuse it pops the second I turn on the lights.
Has anybody else had this problem or any ideas on what it could be?
I hope it could be an easy fix as a weird electrical problem could be expensive and I'd probably have to go to a dealer because I don't know this area (at college).
post Oct 10, 2006 - 8:42 PM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
QUOTE(CCCP @ Oct 10, 2006 - 4:04 PM) [snapback]489988[/snapback]
Did all the lights burn out or just one? If it's was all then it's probably a short in the wiring. If it's just one I'm guessing corrosion inside the bulb socket.
post Oct 10, 2006 - 9:15 PM
CCCP
Joined Mar 22, '03
From NH, USA
QUOTE(AudioFreak @ Oct 10, 2006 - 6:42 PM) [snapback]490090[/snapback]
Both tail lights, it probably is a short -- but how would you find it?
post Oct 11, 2006 - 8:00 AM
AudioFreak
Joined Dec 19, '02
QUOTE(CCCP @ Oct 10, 2006 - 10:15 PM) [snapback]490112[/snapback]
It's probably in the wires right around the bulbs. Just look for any cuts or if the wire goes across something sharp. Basically just start at the bulb socket and work your way forward.
Lo-Fi Version Time is now: January 10th, 2025 - 4:54 AM
