> 6GC A/C installment, How to install the damned thing?
post Oct 11, 2006 - 5:21 AM
IGloo
Joined Apr 1, '05
From Zagreb, Croatia
Basically, I canīt stand the air coming from the A/C unit, since it makes me phisically ill, but this summer was XTREMELY hot here, and I donīt want to lose any more weight by sweating like a pig in my car (Iīve heard somewhere, that sveating is not so good for your seatīs upholstery biggrin.gif )...
Anyway, I was wondering if any of you guys had any experience in installing the A/C system where there never was any...
Please help!
Another proud 6G Celica owner!
post Oct 11, 2006 - 6:35 AM
Griff
Joined May 25, '06
From South Carolina
haha, you need an air freshner!
no, i know what you mean by making you ill,
i dont have any experience with this, but am intrested.
post Mar 5, 2011 - 5:43 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
not wanting to create a new thread, is this the a/c core?? I'm trying to sell it to a member on here
This post has been edited by BonzaiCelica: Mar 1, 2013 - 3:07 PM
post Mar 8, 2011 - 4:51 PM
rave2n
Joined May 29, '09
From Gainesville, FL
I believe I would start my troubleshooting under the hood, via the AC compressor.
post Mar 8, 2011 - 9:41 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
You'd have to do so much work to install a/c i'm not sure if it'd even be worth it. you'd need to wire in the compressor and high side pressure sensor into the ecu. Find all the low and high side a/c lines. Install a condensor, and evaporator (which would require removal of lower dash if not the entire dash). It will be a lot of work involved.
Bonzai it looks like that is the correct box. The evaporator and heater core should be together in the same box i believe.
2nd Gen 3s-gte.... It lives!
97celiman
post Mar 8, 2011 - 10:11 PM
BonzaiCelica
Joined Apr 24, '08
cool thanks
post Mar 9, 2011 - 7:19 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
heater core is in the very middle. behind the radio
post Apr 6, 2011 - 2:22 AM
BonzaiCelica
Joined Apr 24, '08
I removed the a/c line and antifreeze vapor spit out. I chocked up a bit. Is there any other precautions I need to take before I remove the A/C Core??
Also here is what i've removed so far. how the hell do you remove the a/c core?? any suggestions would be very helpful
post Apr 20, 2011 - 3:54 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
theres a bunch of bolts around that box directly to the left of the blower motor
post Apr 21, 2011 - 1:49 AM
BonzaiCelica
Joined Apr 24, '08
thanks anyways but I got this out about a week ago!!
Lo-Fi Version Time is now: November 24th, 2024 - 6:57 PM
