axle..boot, clicking noise |
Jun 29, 2003 - 5:01 AM |
Enthusiast Joined May 15, '03 From So Cal,CA Currently Offline Reputation: 1 (100%) |
does anyone know what might be the problem...i just put on ground control coilovers and in front i have stock shocks..in back i have kyb gr2..i also have bleeding axles on both fronts..prblem is "everytime i turn the wheel to the left..i hear a clicking like grinding sound coming from the inner axle boot or possibly the shock? only thing i did with stock shocks was took of the metal piece that was instructed..when i turn my wheel to the right now...i hear like a gas releasing sound..like shhhhhhhhheeee.. and it only occurs when i turn wheel to the right...dunno what it could be..only the outside axle boots are bleeding...anyone have this problem? "
Andy |
Jun 29, 2003 - 11:04 AM |
sounds like C/V joints....
13.6@108MPH, 5SFTE Powered |
Jun 29, 2003 - 4:13 PM |
Enthusiast Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
Yeah, i get the same kind of popping/clicking sound from my front left axle.....im pretty sure its my c/v joint though. Does anybody know how much it costs to fix the c/v joint? Also, will the replacement last long, becuase my cousin is a mechanic and sems to think that the best route to go is by replacing the axle, since theres a seam on the new c/v joint cover that will eventually rust......someone gimme some input on this.
-------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Jun 29, 2003 - 7:15 PM |
i dont know exactly what to say, but i found the replacement joint bolt and axle assembly for about 90 bux per side...it was an online site, ...i will prob do that..i thought it was the bar on the shocks.....maybe not ..
Jun 30, 2003 - 8:02 AM |
Enthusiast Joined Jun 21, '03 From FRANKFORT,KENTUCKY Currently Offline Reputation: 0 (0%) |
I agree that a new axle is best. You can get one at autozone or whatever and it should cost less than 90$. And if you've got the extra cash, just go ahead and get a new axle for the other side too(although it's not needed),it might save you some trouble later.
Jun 30, 2003 - 1:03 PM |
Enthusiast Joined Apr 10, '03 From South Central Los Angeles Currently Offline Reputation: 0 (0%) |
what 95STHATCH said
Jul 8, 2003 - 10:29 AM |
Enthusiast Joined Jun 10, '03 From FL Currently Offline Reputation: 0 (0%) |
Yea, a CV boot and axle are about the same price. And if your boot has been punctured for some reason you might as well replace the whole axle because if anything got in there then your axle is gonna blow out pretty soon.
Lo-Fi Version | Time is now: November 28th, 2024 - 12:19 PM |
