Car Audio Guys....Got a Question |
Oct 11, 2006 - 10:35 AM |
Enthusiast Joined Sep 23, '04 From Ohio Currently Offline Reputation: 4 (100%) |
ok....so i hear if you put cotton in your box it makes it louder??? am i right or is people just talkin crap to me???
Also, if it is right, does it matter if its ported or not, cause wouldnt the cotton come out in a ported box??? so one give me some insight please! thanks, Dustin -------------------- |
Oct 11, 2006 - 11:22 AM |
Enthusiast Joined Dec 9, '05 From Bedford, TX Currently Offline Reputation: 11 (100%) |
my lil bro did the same thing in his mr2 and it does seem to make a difference. We were told to do that by or neighbor.
-------------------- <--- I miss :'' (
Oct 11, 2006 - 11:32 AM |
Enthusiast Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) |
hmm interesting... id like to know what it does and how it makes it louder
Oct 11, 2006 - 12:09 PM |
Enthusiast Joined Aug 25, '06 From HAMILTON NJ Currently Offline Reputation: 1 (100%) |
basically wut i does and seal the box better and put more pressure on the back of the subs to make them hit smoother and makes the sub stiffer..... And most the time sealed boxs do sound better than ported
Oct 11, 2006 - 12:18 PM |
Enthusiast Joined Mar 24, '06 From Aloha, Oregon Currently Offline Reputation: 5 (100%) |
the cotton or "batting" creates an additional buffer for the soundwaves diffusing noise and vibration on the backside of the speaker.
Ported versus sealed all depends on what sounds you want to achieve. A sealed box produces tighter more pronounced bass "kick" where as a ported enclosure will spread out the low tones and give a wider variety of tones. |
Oct 11, 2006 - 1:04 PM |
Enthusiast Joined Oct 4, '06 From Kelowna, BC Canada Currently Offline Reputation: 3 (100%) |
The cotton won't come out if you use a spray adhesive on the back of the box before you put your batting in there. I use the same spray adhesive for this as I do for carpeting my boxes.
I've always added filler to my boxes. I've heard that adding between 20-40% fill in a box is best, but use a looser fill like quilt batting. Carpet underlay or spray foam is a lot denser and doesn't have a as great an effect on sound waves. I've also heard that the sound wave diffusion caused by the batting creates the effect of having a larger box in a smaller enclosure as the compression is changed. Whether this is true, I don't know, but in all the sealed boxes I have run, I found adding a few layers of batting to it cleaned up the sound and made it smoother. -------------------- |
Oct 11, 2006 - 5:06 PM |
same effect goes for the bass drum on a drum set.
Oct 11, 2006 - 8:30 PM |
Enthusiast Joined Sep 19, '05 Currently Offline Reputation: 3 (100%) |
Poly fil is the most common brand name:
http://www.crutchfield.com/S-Ig1TOlQDh5Y/c...41&I=027808 I used some in my .35 cu ft. sealed box, and I really like the tight bass. Personal preference, really. -------------------- |
Oct 11, 2006 - 8:42 PM |
Enthusiast Joined Jul 23, '06 From Chester - UK Currently Offline Reputation: 0 (0%) |
after years of being an ICE comp sorta person i'd personally say it's worthless unless your sounds are that bad & even then still silly & would rather spend a few pounds on a better amp or sub (nice sounds don't have to skint you out)
-------------------- My Celica Is Now For Sale
Lo-Fi Version | Time is now: January 9th, 2025 - 2:07 PM |
