how do you hook up a manual boost controller?? |
Oct 12, 2006 - 5:48 PM |
Enthusiast Joined May 5, '05 From mattoon, IL Currently Offline Reputation: 2 (100%) |
ok, i have a manual boost controller and i have hooked up up a million different ways and its still not working,, my turbo has 2 ports on the waste gate, and the another port on the turbo itself,, any body know how to run the vac lines for the turbo/wastegate/ and boost controller???
Oct 12, 2006 - 5:58 PM |
Enthusiast Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
cap off one of hte ports on the wastegate and run the wastegate to the MBC then MBC to turbo
do MBC's have ins and outs? This post has been edited by brianforster: Oct 12, 2006 - 5:58 PM |
Oct 12, 2006 - 6:21 PM |
ya its got 2 ports on the mbc
thats how i ran it the first time, and it doesn't work still |
Oct 13, 2006 - 3:41 AM |
Enthusiast Joined Oct 6, '06 From UK Currently Offline Reputation: 0 (0%) |
1. Cut the turbo to actuator line.
2. Splice the turbo end to the in of the boost controller. 3. Splice the actuator end of the line to the out of the boost controller. 4. Cut the remaining actuator line (VSV line) & plug both ends with a bolt or line cap (Make sure you use a clip to hold the bolt or cap in as they could blow out under pressure). Note: Make sure you keep the boost controller box as close to the turbo as possible & the line runs short as possible. If you drop me a pm with your e-mail addy I can forward you some diagrams & pics I made up when I did mine. |
Oct 18, 2006 - 4:21 PM |
Enthusiast Joined Sep 9, '04 From England Currently Offline Reputation: 0 (0%) |
QUOTE(JDM_ST205_WRC @ Oct 13, 2006 - 9:41 AM) [snapback]491110[/snapback] 1. Cut the turbo to actuator line. 2. Splice the turbo end to the in of the boost controller. 3. Splice the actuator end of the line to the out of the boost controller. 4. Cut the remaining actuator line (VSV line) & plug both ends with a bolt or line cap (Make sure you use a clip to hold the bolt or cap in as they could blow out under pressure). Note: Make sure you keep the boost controller box as close to the turbo as possible & the line runs short as possible. If you drop me a pm with your e-mail addy I can forward you some diagrams & pics I made up when I did mine. these are also the quickest way to blow your engine...mine came with a relief valve, one day it went bang, boost went off the scale, no boost controll at all...i could boost to 1.5bar and beyond..melt pistons at 10 paces.. if you want boost control do it right for the sake of your engine..Greddy, HKS, APEXI all do very good electronic boost controllers...whats worth more..a blown 3sgte engine, but a 20.00 relief valve, or a very healthy 300bhp 3sgte with an electronic boost controller? i know what it is in my book. anyone wants a relief valve, let me know, i got one in my toolbox. Adrian |
Lo-Fi Version | Time is now: November 27th, 2024 - 8:28 PM |
