> I have a 8 speaker set up and I have a question., Can I have some feedback for whom that has a *8 sub for the front?
post Oct 12, 2006 - 10:04 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
I have a stock 8" sub as my front speaker and i want to replace it with a JL brand. The JL 8wo would touch the back of the door shell vs the 6" will have room.
Would it better with a midbass 6.5" or a 8"?
Also how would i change from a 8" set up to a 6.5"?
Also if you have an aftermarket 8" sub for the front whats your feedback on it?
This post has been edited by My2Celi: Oct 12, 2006 - 11:55 PM
IPB Image <--- I miss :'' (
post Oct 12, 2006 - 10:54 PM
trdproven
Joined Aug 2, '05
From Guam
If you can find a bracket or make one. Check online audio stores for them like crutchfield. JL's will either be too tight or won't fit and they won't give enough space to breathe. What you need are midsubs, which are shallow subs.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 12, 2006 - 11:43 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
ill search for a midsearch and see whats a/v. thanks dood. any other suggestion?
post Oct 12, 2006 - 11:56 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
Check this midbass from JL.
MIDBASS
post Oct 14, 2006 - 9:24 AM
nightrider
Joined Apr 26, '04
From London
Pioner do a 3 way and componant set that can go into the doors as OEM. you will have to relocate the tweeters behind the door mirrors, but this will look and sound sweet.
More Power to your BOOM BASS
post Oct 14, 2006 - 11:10 AM
My2Celi
Joined Dec 9, '05
From Bedford, TX
thanks for the reply man. i have made up my mind to go with the 3 component JL xr653 and for the back 6.5" ima go with there 6.5w0 sub. If i dont like it ima just make a full back trunk custombox. I have already taken the back seats. I decided to not have a back seat at all or just make the back into a bed or someting.
post Oct 14, 2006 - 11:23 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
I have the 8 speaker setup and have fitted Kicker Resolution RMB-8 8" midbass speakers in my factory location. They work great and along with my 10" sub in the trunk adds a very full sound to my soundstage.
If you would like to see my setup or want more details, just look in the stickies in this forum and you'll see my full writeup on installing new speakers into the 8-speaker configuration.
post Oct 14, 2006 - 4:58 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
thanks dood. ill look into that.
post Oct 18, 2006 - 3:20 PM
BenMMellor
Joined Dec 24, '02
From Wirral, UK
i've just fitted some Pioneer TSE2096's (3 ways) to replace the stock front speakers.
I had to make my own mounting out of MDF and dowels but they fit ok - i did have to dut a bit off the inner door skin to fit the magents behind.
Taking the easy option with the rears and have managed to source some new boxed TSE1675's
post Oct 18, 2006 - 3:24 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
nice. how does it sound so far? i think im going for the jl 3 way system. its gonna be a 6.5" in the front, 4" for the mid and 1" for the tweeter. For the rear speaker i think ima go for the 6.5 sub for the rear speaker. what do u think?
post Oct 18, 2006 - 7:27 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
I fit a pair of alpine 8" subs in the front last fall. I had to cut into the door and shape the plastic speaker holder to make it fit but I think it was worth it. I opted for a seperate amp for the subs and got rid of all the factory amps.
post Oct 18, 2006 - 8:58 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
no rattle rocket? you know for some reason i water leaks in my door. I think the weather strip on my door is worned out or something and im scared that water touching speaker = shock.
This post has been edited by My2Celi: Oct 18, 2006 - 8:59 PM
post Oct 19, 2006 - 3:24 PM
BenMMellor
Joined Dec 24, '02
From Wirral, UK
TSE2096's are sounbding good - when I bolted the speaker mounts to the door I made sure I had strips of dynamat on the door skin first - they can go pretty loud without any issues.
No-one ever seems to do a write-up/pictures of swapping out the rear speakers so I think I'll do that this weekend.
post Oct 20, 2006 - 2:29 PM
jess_i_74
Joined Sep 19, '05
I fit JL 8w0's in the front of a '95 convertible. Required a bit of modification for the brackets, but definitely fit depth-wise. Great bump; would have helped if it was dynamatted.
post Oct 22, 2006 - 1:54 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
QUOTE(My2Celi @ Oct 18, 2006 - 6:58 PM) [snapback]493355[/snapback]
I'm getting a little rattle from the right sub but I'm possitive it's the wiring harness that runs over the top of it. I didn't evern think about securing it before I put the door back on. The sub sticks into the door only about another inch so I'm not too concerned about water.
Lo-Fi Version Time is now: January 9th, 2025 - 2:12 PM
