![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '06 From UK Currently Offline Reputation: 6 (100%) ![]() |
Hi, does anyone know which of these wires (from the ignition barrel) are the two Starter wires that go to the starter motor solenoid? I think one is the BLACK/WHITE one, but which is the other one?
![]() Also, the wires to the Cigarette lighter: Which are the power wires to the lighter? ![]() If anyone can confirm these: the Connector Numbers for top picture: 1- Black/White = Starter??? 2- Black/Red = ? 3- Black/Orange = Power? 4- Blue/Red = Power? 5- Grey = ? 6- empty 7- White = ? 8- empty Apologies for my complete electrical n00biness ![]() This post has been edited by manphibian: Oct 13, 2006 - 6:00 AM -------------------- |
Enthusiast ![]() ![]() Joined Dec 19, '02 From West of Atlanta Currently Offline Reputation: 1 (100%) ![]() |
Don't have a print with me right now so I can't help with the starter but the lighter power is the 2 plugs with one wire in each(not the green/white wires). Power is the wire going to the center point.
QUOTE(AudioFreak @ Oct 13, 2006 - 7:06 AM) [snapback]491127[/snapback] Don't have a print with me right now so I can't help with the starter but the lighter power is the 2 plugs with one wire in each(not the green/white wires). Power is the wire going to the center point. Thanks for that ![]() The other bit i'm confused about is: My starter button instructions say i have two wires to connect to the two wires that go to the starter motor solenoid. Now it seems on the car there is ONE starter wire (white/black) and TWO ignition wires (black/orange and blue/red) Do i need to connect the start button to the two ignition wires? And then i need to connect two other wires to the power wires that go to the cigarette lighter. man i'm confused easily ![]() This post has been edited by manphibian: Oct 13, 2006 - 7:21 AM -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) ![]() |
Install the switch between Black-Red and Black-White. Turn the key to ON and push the button and it will start.
http://www.celicatech.com/vfewdsou/1995/95...ric/start5s.pdf -------------------- ![]() Project ST204.5 99.88946% complete... |
QUOTE(WannabeGT4 @ Oct 13, 2006 - 7:28 AM) [snapback]491130[/snapback] Install the switch between Black-Red and Black-White. Turn the key to ON and push the button and it will start. http://www.celicatech.com/vfewdsou/1995/95...ric/start5s.pdf Thanks a lot, i'll give it a go ![]() -------------------- |
Thanks guys, sorted now.
My gimmicky Engine Start button is installed! ![]() -------------------- |
Lo-Fi Version | Time is now: February 13th, 2025 - 6:09 AM |
