Remove and paint Interor on a Celica GT-95, Remove and paint Interor on a Celica GT-95 |
Oct 14, 2006 - 7:18 AM |
Enthusiast Joined Oct 14, '06 From Sweden Currently Offline Reputation: 0 (0%) |
Hello, i'm a kind of new hear so.
I was looking through the forum and didn't find and Guide how to remove the Interior panels. Can someone please make a guide och describe to me how to do it ? And i also wonder how you painted yours interior ? Plasic primer, Paint and clearcoat ? Did you leave the joob away pr did you do it yourself ? |
Oct 14, 2006 - 9:52 AM |
I was looking through the forum and didn't find and Guide how to remove the Interior panels. Can someone please make a guide och describe to me how to do it ? And i also wonder how you painted yours interior ? Plasic primer, Paint and clearcoat ? Did you leave the joob away pr did you do it yourself ? One last question. Do i have to remove the hole door panel when i want to paint the panel that contains buttons for sidemirrors and windshield functions ? |
Oct 14, 2006 - 10:06 AM |
Enthusiast Joined Jul 6, '06 Currently Offline Reputation: 1 (100%) |
most of the interior pannels jsut pop rihgt off.
the door handle pannel thign is held in palce by a screw the main console is held in palce by a few screws, jsut use a screwdriver to get under it. adn then pull it off gently the air vents work the same, jsut pop em off adn the pannel below ur steering wheel has a few screws holding it in place on the underside. and anythign else i may have forgot....pretty much jsut pops off....jsut be careful when you do it as not to be to rough with it. -------------------- KB |
Oct 14, 2006 - 10:13 AM |
Okey thanks, i took of the center panel earlier today and that one was easy, and the right air condition vent is easy to, the panel behind the door lock is also easy because there are just a screw but the ones i have problem with is the windshield controller, left vent and the panel around the gauges and steering whell. I took of the screws but it didn't wont to pop out
Sorry for my bad english. |
Oct 14, 2006 - 10:38 AM |
not sure what teh winshield control ur talkign about....the left went should work the smae as the right vent. alll the pannels around the gauges, are held in by screws, jsut look all around it...up,donw,left,right and you will find hte hidden screws.
adn the steering wheel one, might take a lil bit of trickery to slide off, casue its connected by a few wires, so jsut slide it around and it should come off....well it wont come offf, but it will hang there -------------------- KB |
Oct 15, 2006 - 4:15 AM |
Enthusiast Joined Jul 28, '06 From Los Angeles, CA Currently Offline Reputation: 0 (0%) |
The passenger side vent, I ended up breaking off a couple of tabs to get it out. But it went back in no problem and doesn't seem to move around or anything.
Oct 15, 2006 - 6:03 AM |
How do i remove the power window button controls panel ? Does i have to remove the hole door panel ?
And how do i remove the lite round panel around the ignition/starter ? And where do i find white gauges with km/h marks ? Thanks for helping me, this is a real good site |
Oct 15, 2006 - 7:07 AM |
Enthusiast Joined Jun 13, '06 From Omaha, Nebraska Currently Offline Reputation: 11 (100%) |
The power window button control panel snaps and slides into place. On mine I had to pop it up nearest the bottom and then slide it down out of a tab at the front of it. I have never messed with panels around the ignition though.
-------------------- We shall show mercy, but we shall not ask for it. |
Lo-Fi Version | Time is now: November 27th, 2024 - 5:38 AM |
